Computers & Internet Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gateway laptop reset
I have a Gateway T-series laptop, model w350a. I am trying to restore it to factory settings. I have lost the system disk in a recent move to another state! I have tried the F10 option, Alt-F10. System restore won't work either. It tells me it can't restore to the points it shows available. I need to restore this laptop ASAP. There is too much spyware and programs on it, so it makes my laptop run slow. I just need a fresh start!
Anyone know how I can get this done? I do have a recovery partition, that I don't know how to access. There is a file named Recovery. I find Info, file type application. This is locked. I click it open and it says PC Angel, contains files for your system recovery.
I can't use anything over there that I know of. Any ideas! Thanks for the help.
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Mar 14, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262605
Points
1837
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
How do I factory reset my gateway model kav60
Restart the system. At the initial BIOS screen press ALT + F10 to access the e-recovery option. Follow the instructions.
Be aware that any data or programs you have added or installed after the machine was first powered up will be lost. This includes all accumulated operating system patches and updates. Be sure to back up any files or data you wish to save and be make sure you have the install media and product keys/serial numbers for any software you have installed since the machine was new before restoring the system to its factory default state. I suggest using one of the many available disk imaging programs to make a full backup of the hard disk that you can revert to if the restore process fails for any reason.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
I have Gateway T-Series W350A Windows Vista Home Premium Japanese model. I would like to increase hard disk space for Windows 7. Can I uprade the hard disk?
Yes you can upgrade the hard drive.
You just need to pull it out and find if it is a SATA or an IDE
SATA has slots and IDE has pins.
I have a Gateway MT-6451 laptop and want to restore to factory condition. I lost the disk. Is there anyway I can perform this without the disk? Or a way to purchase the disk?
The disc is critical when you want to go back to factory settings, check out www.ebay.com there are sellers that provide a lot of different restore discs, you might get lucky. The other option is check www.gateway.com see if the have the supporting disc.
Can I upgrade my Gateway laptop model W350A to Windows 7?
I have this laptop, too. The model number on the bottom is W350A and the screen case has a label that says "T- Series". So, what is the model number if not W350A?
1helpful
Please tell me what the serial number an series number is for Gateway Laptop, T-Series, Model No. W350A?
the serial number is usually found at the bottom of your laptop, is not something that can be given to you online.
you may also want to try to do obtain your system info by going to
start>run> then type msinfo32 and press enter. a box will appear with your system info, it's possibly the your model number and other details that you may require could also appear there.
hope that helps!
Trying to restore back to factory what can i
When you purchased the computer, you should have received a set of "System Restore" CD-ROMs. Use them.
If you have lost them, telephone HP/COMPAQ, and order a replacement set of "System Restore" CD-ROMs. The cost could be $20 for the set, and $20 for courier-shipping. When the disks arrive, use them.
P.S. Backup all your music/files/bookmarks/contacts before doing the "factory" reset.
21helpful
3answers
Trying to do a full factory recovery on an M Series gateway note
If you want to do the factory recovery, 3 ways to do the system recovery
First way
1 login to windows
2.click Start
3. click All programs
4. click Gateway
5. click gateway recovery manager
6. click restore
7. select systems recovery to factory defaults
Computer will restart itself and start doing the system recovery itself, All you need to do is follow the screen
2answers
Gateway Laptop W350A
what memory board use gateway w350a
Grand Canyon Tech
Grand Canyon Tech
