After you have disconnected the brake hydraulic hoses (left & right) remove the brake parking cable. Place a jack on the beam just so that it catches it. Secure the beam with a ratcheting nylon strap or equivalent to the exhaust hanger anchors, not on the rubber hangers. Next you remove the bolts that secure the beam.
You will need
or equivalent special tools to remove (press out) and install (press in). If the bushing is Hydraulic bonded you will need a plastic catch to contain fluid while pressing out.
SOURCE: Ford Escape Trailing Arm
hi there this is a problem with all shocks and swing arms where the bolt goes through a rubber bushing and the water and road salt debris gets into bushing and freezes up causing the bolt to stick into bushing use a prybar to dislodge bushing from the area where its been clamped into it will come out
SOURCE: 2004 Nissan Quest front control arm bushing replacement.
You can get just the bushings at autozone, checker, napa auto part stores for about $30.00 to $35.00. You can replace them yourself or take the vehicle to the shop.
GGBMDB
SOURCE: Top suspension arm bushes worn on my 1996 Lexus LS400
If you can find replacement bushings, take the control arm to a machine shop and have them replaced. The bushings are pressed in and you would spend the entire weekend trying to get them out by hand.
SOURCE: removal/replacement of upper control arm bushing
the a arms need to be removed, and the bushings pressed in and out , then you will need to reinstall them and the truck will need a front end alignment. You really need a qualified person to do this.
SOURCE: My mazda makes a clunking noise.
it sound as if your sway bar bushing is worn give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
