Acer Aspire One Netbook 8.9" Notebook Logo
Anonymous Posted on Mar 14, 2010
Insuffient system resources exist to complete the api
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Mar 14, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262639
Points
1837
Your problem can be cured by simply increasing your paging file size or adding more Ram. Here is an explanation of what an API is and does.
An application programming interface (API) is an interface implemented by a software program to enable interaction with other software, similar to the way a user interface facilitates interaction between humans and computers. APIs are implemented by applications, libraries andoperating systems to determine the vocabulary and calling conventions the programmer should employ to use their services. It may include specifications for routines, data structures, object classes and protocols used to communicate between the consumer and implementer of the AP
Testimonial: "Thanks! Now all I need is to find someone to tell me about Ram and where I can get it."
  • Anonymous Mar 15, 2010
    Post the model number on the underside of the laptop and make that a question. You'll have an answer in no time.
Every time I attempt to log on, I get the message "insufficient system resources exist to complete API. WHAT DOES THIS MEAN? What has happened? How can I fix?
"insufficient system resources exist to complete API." This problem occurs because the Windows kernel power manager cannot obtain the memory resources that are required to prepare the computer to hibernate. When you experience this problem, the hibernate feature is not available on the computer until you restart the computer.
This problem typically occurs when the computer uses 1 gigabyte (GB) or more of RAM.
you can fix this problem by downloading hot fix through this link below
http://www.microsoft.com/downloads/details.aspx?FamilyID=4cbc68d2-09e1-4511-af14-03f357180135&DisplayLang=en
hope that was use full to you
I use outlook express.it creates trouble today. i restarted my pc. then a notice showing " insufficient system resources exist in API" & i cant log i n my windows. when click ok Or close into it then...
hi dear
Insufficient system resources exist to complete the API
download update for windows xp (KB909095) and install it
http://www.microsoft.com/downloads/details.aspx?familyid=9D20F96A-A8D6-4627-89F7-787CD9B3852C&displaylang=en
if you do not able to install the fix
then boot your system with one boot cd and replace your page file with another one
1helpful
2answers
Acer aspire net book shows system error, and won't start up
Shoot it?
Yes, this is one solution. Not very cost effective though.
(Tempting though, huh? One 12 gauge blast, and.....WAIT! Back to the solution, lol!)
No, I suggest you install the Hotfix from Microsoft instead.
http://support.microsoft.com/kb/909095
System error, insufficient system resources exist
1) Install CCleaner and run it.
2) Right Click on "My Computer", Select properties > Select Advanced > Click Settings under Performance > Select Advanced > Under virtual Memory Click on "Change", Select " System Managed Size" and Click on OK and exit. Reboot your System. It should be fine.
2helpful
2answers
Insufficient system resources exist to complete API
Install Win XP KB909095 and increase the size of page file
Insufficient system resources exist to complete the api
The computer occasionally does not hibernate and you receive an “Insufficient System Resources Exist to Complete the API” error message in Windows XP with Service Pack 2, in Windows XP Tablet PC Edition 2005, or in Windows XP Media Center Edition 2005. Apparently, the problem is caused by the fact that the Windows kernel power manager doesn’t manage to find a block of contiguous memory to hibernate. This happens occasionally on laptops with 2Gb of RAM. It can be quite annoying when you put your laptop to sleep, pop it in your haversack, then some time later find a discharged battery and a VERY HOT laptop bag , it’s nice that they solved the problem, HOWEVER, you can’t actually download the hotfix, but have to contact Product Support Services for it. I’m not sure if there’s a fee to be paid for it, so I just Googled the hotfix and found a copy elsewhere.
Here’s a copy if anyone wants it: Download here: http://www.u-g-h.com/content/binary/WindowsXP-KB909095-x86-ENU.exe
Periodic error message
Hi davebuechler,
there is a fix for this through windows update service. Check these other links first.
http://translocator.ws/2005/11/06/hibernation-insufficient-system-resources
Hope this helps!
Good luck davebuechler!
Mike
Acer travelmate 2300
it indicates a virus..would suggest you to take backup of your data if possible and reinstall the os
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
