People on other posts said to get a wall charger and that'll work. We looked for one, but couldn't find one. We ended up using a usb camera upload cord that had the same connector. It charged just fine after that. We have a 180 Eclipse mp3 player...I'm guessing the cord connectors are pretty universal.
Plug up to the computer and go to computer and go from there
I had problem with Eclipse CLD - won't charge/connect to PC. Problem Solved! Try another USB cable - that simple! The one I used I bought at the Dollar Tree Store for $1.00. If you are trying this idea, bring your original USB (short length) cable with you to match the shape and size of your Eclipse connector since the store has different ones. Good luck! Charging away listening to Deadmau5 through the PC and a 3.1 FROM the Eclipse.
Go to this link and read the answer by Einat B.
http://answers.yahoo.com/question/index?qid=20111223190811AA0Xpyw
SOURCE: Eclipse MP3 Player
The official unofficial REAL Answer is here!!
I swore it off as Junk untill I took the time to figure this out.
When charging the power swith needs to be in the "ON" position.
Charge for around 3-5 hrs.
To turn device ON You hold down the Play/Pause button for quite some time, (much more time than expected from other players,cellphones or devices) the unit should power up and display "ECLIPSE".
I thought I was "taken" and strange when I saw the link for Qresolve within the files of something that did not work.
Theres even an EQ feature in the Menu and the sound is pretty decent. Good Luck!
i had my mp3 player hooked up all night and it did not charge at all. can i get some help
I've lost the cord, for mine. The usb cord for a Garmin will turn it on, but won't charge it.
