I have a Honeywell Focus Pro 6000 thermostat that I need the installation instructions for. The model on the outside of the box is TH6110D1039. Thanks Robert
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Right below the w setting on the base plate is the o/b connection. Put the O wire in this slot. During the initial test for heat and cool, the bias for cool for function 2 is 0 and for heat it is 1. To reach the programming press fan and Up arrow. Press next to reach function 2. Be aware the the O wire is energized and operates the reversing valve. Some manufacturers energizes the reversing valve to go into cooling, and some leave it deenergized to be in cooling. Select either 0 or 1 to make the system perform in the correct mode.
Hope this helps.
google honeywell & see what you fined . maybe( honeywell 6000) there should be a number for you to call... alot of thermostats have numbers with it just incase of your problem , should be on the back of it or inside the box the stat came in...
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
HONEYWELL WEBSITE:
Go to honeywell.com
HONEYWELL WEBSITE:
Go to honeywell.com
