There are several options but the most practical one is to get a scanner that scans transparencies. They are not cheap but are the most effective. Another option is to project the slides onto a special screen and then photograph them with a digital camera. This can be done with 35 mm negatives as well and then they can be turned into positives with software.
I inserted my negative holder in backwards on my Nikon 5000 35 mm scanner. Then I could get the last (5th) slide scanned. But I can not get the scanner to work on my new IMac because of no working driver. Silver Fast has no drivers for the Nikon 5000
Click Settings > Scan Settings > Button Settings at the bottom of the left pane.
Click the Scan Picture Button tab. Under "Scan to" select the program you would like to edit the image with after the scan is finished.
Repeat step 2 for the Scan Button, the Scan Document Button and Scan Film Button. Select the program you would like to use to open each type of scan, or select "Save to File" and the desired file type. Select your preferences under the Document or Picture menus based on the type of image or document you will scan most often using this button. Ensure that the "Show Preview" check box is checked for each button type. Click "OK."
Place your document or picture on the glass. If scanning film, place the 35 mm negative or slide in the special adapter provided by HP. Select the Scan Picture, Document or Film button depending on what you are scanning. Select the Make Copies button to copy the document or picture directly. Click "Scan" and then "OK" to see the scan preview.
Crop your image by clicking the small black boxes at the edges of the selection area. Drag your mouse until the portion of the image you wish to scan is selected. Select the image correction settings in the menu on the right to fix any problems with the picture or document. You may also change the image resolution and resize the image in these menus. When you're finished, click the "Accept" button. If you'd like to scan another image, select "Yes" in the next dialogue box. If not, select "No."
Place your document or picture on the glass. If scanning film, placethe 35 mm negative or slide in the special adapter provided by HP.Select the Scan Picture, Document or Film button depending on what youare scanning. Select the Make Copies button to copy the document orpicture directly. Click "Scan" and then "OK" to see the scan preview.
The HP Photo Smart 35 is a USB printer. Your computer has USB ports. You can utilize an open USB port on your computer to connect the printer. What is a CS100-818035 plug?
