Linksys Cisco SLM224G Managed Ethernet Switch Transceiver Logo
Posted on Mar 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need help... is there a way to reset the switch login password?
Anonymous
Level 3:
  • Master 797 Answers
  • Posted on Mar 14, 2010
Anonymous
Master
Level 3:
Answers
797
Questions
Helped
191156
Points
2336
You can reset it to factory defaults in which case it will have the factory default login.
Reset — Press and hold the Reset Button for less than ten seconds to
reboot the switch. Press and hold the Reset Button for more than ten
seconds to reset the switch’s settings to the factory defaults.
The steps I should do for forgetting passwords when I use switches?
This needs to be discussed in different situations, you can check whether these situations can solve your current problem.
Scenario 1: All Default Passwords Are Changed and All Passwords Are Forgotten If you change all default passwords and forget the console port login password, all STelnet/Telnet login accounts and passwords, and BootROM/BootLoad passwords:
·For a switch that has the PNP button, you can press and hold the PNP button for more than 6 seconds to restore the switch to factory settings and restart the switch. The following figure shows the PNP button.
·If the switch does not have the PNP button, return it to the factory for repair.
Scenario 2: Default Passwords Are Forgotten For S series switches running V200R020 and later versions, no passwords are configured for default accounts, and users must configure new passwords for logging in to the switches. In this situation, scenario 2 is not involved.
However, for S series switches running versions earlier than V200R020, there is no default STelnet/Telnet login password, but there are default console port login password, default BootROM/BootLoad password, and default web login password. These default passwords may vary according to the switch version.
If you always use the default passwords and have not changed the passwords, you can obtain the default accounts and passwords according to S Series Switches Default Usernames and Passwords (for enterprise users or carrier users). The permission level of this document is C (customer support level). If you need to upgrade the permission level, see the help document on the website.
Scenario 3: The Console Port Login Password Is Forgotten Three methods are available to recover the console port login password.
·Method 1: Log in to the device using STelnet or Telnet and change the console port login password.
·Method 2: Clear the console port login password in the BootROM/BootLoad menu and change the console port login password.
Scenario 4: The STelnet/Telnet Login Password Is Forgotten ·If you forget the login password of an STelnet/Telnet account, you can use another STelnet/Telnet account with administrator rights to log in to the device and reset the password. For details, see Method 1.
·If you forget the passwords of all STelnet/Telnet accounts but can log in to the device through the console port, see Method 2.
Method 1: Use an STelnet/Telnet Account with Administrator Rights to Log In to the Device and Reset the Password
1.Log in to the switch using the STelnet/Telnet account with administrator rights.
2.Change the STelnet/Telnet login password. The following example describes how to change the STelnet/Telnet login password of VTY0 to VTY4.
Method 2: Log In to the Device Through the Console Port and Set a New STelnet/Telnet Login Password
If you forget the STelnet/Telnet login password but remember the console port login password, log in to the switch through the console port and set a new STelnet/Telnet login password.
Scenario 5: The BootROM/BootLoad Password Is Forgotten but the Console Port/STelnet/Telnet Login Is Available If you can log in to the switch through the console port, STelnet, or Telnet, log in to the switch and restore the default BootROM/BootLoad password. You can obtain the default accounts and passwords according to S Series Switches Default Usernames and Passwords (for enterprise users or carrier users). The permission level of this document is C (customer support level). If you need to upgrade the permission level, see the help document on the website.
Scenario 6: The Web Login Password Is Forgotten but the Console Port/STelnet/Telnet Login Is Available If you can log in to the switch through the console port, STelnet, or Telnet, log in to the switch and reset the web login password. In the following example, the web login user name is admin123 and the password is test@123.
For more reference resources, please click to enter (ebook) CloudCampus 3.0 Solution:
https://support.huawei.com/enterprise/en/doc/EDOC1100201111
OR you can straight to see this decument
https://support.huawei.com/enterprise/en/doc/EDOC1100200698#section1612361212554
1helpful
How do I fully reset my AP7161
LOST ROUTER LOGIN PASSWORD
If you have forgotten your personal router login password there is no way to recover it. You will have to reset the router. This means all the settings on the router will be reset to factory defaults. It also means that all your connected devices will need to be connected again with the new security information (WEP, WAP, etc,) . You will need the default admin login name and the default admin password. This can be found in the user guide that came with the router. This can usual be found online at the router manufacturers site.
There is usually a button or a switch hidden in a pinhole opening on the back of the router. Pressing and holding the switch for 10 seconds or so will cause the reset and usually the LEDs will flash and blink for several seconds as the router firmware sestets and clears out the old information.
If you are trying to get into someone else's router illegally there is no way to find out their login password.
For future reference, write the password down, or a hint at what the password is, on a piece of tape and secure it on the bottom of the router. I use my cell phone memo function to store all my passwords.
Forgot administrators password, have no reset disc, windows 7. need pathway in command promt
This article describes how to reset windows 7 password without disk when forget login password and locked out of your laptop or computer.
If you are still bothered about forgetting windows 7 password and have no reset disk, the methods described in this article will help reset the lost password with or without disk. You just need a few minutes to read these methods in this article, and pick the right one to take it to carry out.
Method 1 and Method 2 describe how to reset a user account password under the condition that you can login your comptuter with another administrator account.
Method 3 shows how to reset a lost password with windows 7 password reset disk which you have created before forgetting login password.
Method 4 tell you how to reset or recover windows 7 login password with a password recovery software.
No Bull I bougth a DES-3350SR D-link I need to reset the password.
http://www.helpowl.com/p/D-Link/3350SR/Research/20945?search=des%203350sr%20setup
DES-3350SR Layer 3 Fast Ethernet Switch Users Guide reset Restrictions Only administrator-level users can issue this command. Example Usage:
To restore all of the switchs parameters to their default values: local>reset config Command: reset config Success. local> login Purpose Syntax Description Used to log in a user to the switchs console. login
This command is used to initiate the login procedure.
The user will be prompted for his Username and Password. none. none. Parameters Restrictions Example Usage: 46
hope this helps
Forgot login & pwd
If all else fails and you cannot remember your login information use a toothpick ir a similarly small object and press the reset button, Usually located somwhere on the back of the unit, look for a small hole the reset button is usually not visible but is just inside the small hole, press and hold this reset for 10 seconds or more and it should reset to factory defaults including the login info then you can access the unit using the factory login info. usually USERNAME: admin PASSWORD: password
Hope this helps Good Luck!!!
2answers
Password recovery steps for lucent dsl max 20 dsl terminator
You have been prompted for the login password and received the following message: “Login Password isinvalid”.• Re-enter the correct password and press enter. Remember that the password is case-sensitive. Check that youare entering admin in lowercase and that the Caps key is not active.• If you have forgotten the password, you must reset the login password. Refer to the User Guide, ChangingConfiguration Switches, and perform the following procedure:1. Move switches 5 and 6 down.2. Type login <newpasswd>. Password checking is overridden.3. Move switches 5 and 6 up.4. Complete any configuration update that caused the prompt for login.5. Change your login password to a new password.6. Store the configuration and reboot the router.Note: If you have not reset switches 5 and 6 to the up position and have rebooted, this will place the router inmaintenance mode. Set switches 5 and 6 up and turn the power off and
www.alliedtelesyneurope.com/media/.../manuals/rg624-34_um_a.pdf
2helpful
2answers
Default login & password
Default password for most of the modem is "admin"
If it doesn't help, then it will be mentioned in your modem user manual. For resetting your modem, you can use the hardware reset switch also. You can reset using that by inserting a small pin/needle into the hole located somewhere behind the modem.
9helpful
3answers
Password reset for ATEN kvm switch
If you are unable to perform an Administrator login (because the Username and
Password information has become corrupted, or you have forgotten it, for
example), there is a procedure you can use to clear the login information.
To clear the login information do the following:
1. Power off the CN8000 and remove its housing.
2. Use a jumper cap to short the jumper on the mainboard labeled J6.
3. Power on the switch.
4. When the front panel LEDs flash, power off the switch.
5. Remove the jumper cap from J6.
6. Close the housing and power on the CN8000.
After you start back up, you can use the default Username and Password (Login: administrator, pass: password).
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
