If the day will not change when you pull the crown out to the first position (try both directions) then pull the crown out to the second position. Advance the hands until yesterday shows in the day window. Now set the date by putting the crown in the first position and set it to yesterdays date. Now advance the hands (position 2 until the date and day change and then set the time. Done
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
mcdevito75 here, The stem has 2 positions, first adjust the day or month by going thru the 24 hour cycle with the stem. once set, slip a finger nail just ubder the stem and lift carefully this should allow you to change the DATE adjust to 1 date before the date you need, now pull the stem out to adjust date and time of day turn sten the complete 24 hour cycle to achieve the correct date and time of day. Now your watches day and date are set and will change to the next day date on time, around Mid nite 1 --2 AM.
Check that you have set the time at the correct AM or PM setting. If this setting is wrong it may appear that the date is changing in 12 hours because it sees 12 midday as 12 midnight.
If this resolves the issue please do take a moment to rate my answer. If not please use 'Add comment' or 'Continue with this Expert' to post up the details. I will be happy to respond.
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal. That's how you do it. If you need more clarification let me know.
Hi Jeffrey, Put stem into "set hands" position and adjust hands to the 12:00 position. Day and date should advance at or close to that time. If you pass 12:00 and there's no change continue rotating another 12 hours and they should advance. Once youv'e found that there's midnight so if you're setting the time at say four (4:00) in the afternoon (pm) you will neew to rotate the hands so around the dial so they pass 12:00 once more then four hours more to 4:00. Now I assume by bilingual you mean that the day ring has like Mon (monday) and Lun for Spanish or the like. In this case if it's showing the wrong languare set the crown (winder) to the first position (second posn is "set hands) and rotate winder eithr clockwise or anticlockwise. Once you discover how to advance the day ring just set it to the correct day/language you want and press the crown home. Hope this solves your problem. If the advances are changing at some obscure time like 8:40 or something it's because the hands pave been located incorrectly and would need correcting by removing movement from the case.
I don't know this watch specifically but typically the following applies:
To set the day/date you set the crown (winder) to the first position (second posn is "set hands) i.e. pull out one stop, and rotate winder eithr clockwise or anticlockwise. Once you discover which direction advances the date and day ring just set it to the correct day/language and date you want then press the crown home.
