Hey Doug,
Just wondering has this unit ever had the running deck flipped over if not this may be sighs of worn deck or belt or both! What is starting to happen is that at the higher speed the unit is starting to draw more current, so the motrol control board will sense this and will shut down so it won't damage either the motor or board. What starts as an occassional shut down will progressively become more frequent. Simple test is put your hand palm down between the belt and deck,if you feel uneven ridges then the deck needs to be flipped over and when you pull out your hand out and their is a black sooty film on the back of it ,then that seals it this means that the composite material is being shaved off. Most likely the belt will have a smooth glazed feeling in the middle part of it. and well also need replacing.
HI , Check this link for more details about PRECORE error codes http://electro-medical.blogspot.in/2013/...
