Dirt Devil Reaction Twin Cyclone Upright Vacuum Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our Dirt Devil D2 bottom has no suction
Our Dirt Devil D2 has great suction through the hose but the bottom has poor suction. I have to vac the floor with the hose. Help please. How do I fix it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 24, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1567
Points
Check to see if the belt needs changing.
Anonymous
Level 3:
  • Master 337 Answers
  • Posted on Mar 13, 2010
Anonymous
Master
Level 3:
Answers
337
Questions
0
Helped
133701
Points
1057
I would check the bottom of the unit to see if there is any blockage. I don't know if this unit has a switch that you set to switch from hose to floor. If so I would set it to floor and see if there is any suction in the hose, indicating a switching problem. If there is no suction in the hose, I would still check the bottom of the unit and disassemble it as much as you feel comfortable to see if you can see any blockage. Good luck!
  • emdeplum Oct 29, 2010
    Belt is good, doesn't appear to be clogged, stuck the hose in the bottom of mine and the air seems to flow good through the bottom but still no suction at the bottom when i return the wand?
Dirt Devil Total Pet hose not suctioning
The hose must be blocked. Push a broom handle down it.
Dirt not going into vacuum canister on dirt deval
It sounds like there is a clog in the hose itself if you have no suction from the end. If it is bagless remove the canister from the machine or if it is a bagged machine remove the bag. If you have a shop vac attach the hose from the shop vac to the end of the hose of the dirt devil and try to suck the obstruction out that way. Sometimes it is possible to remove the clog this way. You can tell if you have suction from the debris port to the bag or the canister. If not you may need to use a snake or coat hanger to pull the clog through.
My Dirt Devil en vision hose has good suction but zero suction at the bottom. Clean filter,no clogs.i know replacing the broken belt will make the brush turn. Will it enable suction also?
If you have fixed the suction at the bottom, a new tight belt is important when vacuuming carpeted floors. Belts lose elasticity from being stretched which is why they need replaced frequently.
Side hose suctions fine, but floor base does not suction.
You most likely have blockage at the bend in the suction tube below where the hose plugs in to the vac. Try using a coat hanger and see if you can remove any debris that way. Alot of vacuums have a screw that you can remove that will allow better access to this commonly clogged area. It will most likely be visable very near where you plug the hose back into the vacuum, when the hose is removed.
12helpful
2answers
No suction on floor part
From your problem description, you may have a blockage in the foot. Check the intake under the vac by the roller.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
The basic floor part has no suction. the attachment does have suction.
Your problen sounds like it is in the foot of the vac. remove the bottom plate and look for an obstruction.
No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
2answers
No suction
Check the main filter cone - if it has a rip in it, then there won't be any suction in it, also clean it gently with a paint brush to get all of the dust out and check the back of the upright after the bin is taken out as sometimes there is dirt clogged at the back. Check the front of the sole plate i.e. where the roller brush is and check the dust channel behind this as it can get clogged. Due to the nature of this vacuum with the hose being located at the front of the floor head dirt can be trapped but most of all its the paper pleated cone filter that needs a good brushing. Hope that helps.
3helpful
2answers
Dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Top Dirt Devil Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
NOEL
NOEL
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
