The printer still reads as though I still need to replace cartridges
The version of firmware you originally had on the printer when you
changed the ink cartridge was bad. There is a known issue that when you
put in a new ink cartridge when the printer is in the error state
"COLOR INK
EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the
new ink cartridge so you will continue to have that error.
So to fix
your problem Open the access door and Remove the ink cartridges. Then download and install
the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank
and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
Go to the Kodak website and download the new freeware. It will take care of the problem.
SOURCE: new ink cartridge for Kodak Easy Share 5300 will not work
"COLOR INK
So to fix
and install it.
I hope this helps
biggest piece of **** ever!!
