Remote codes for TV needed
I have a PhilipsUniversal Replacement Remote Control, I lost the book with the codes, and I need to set up the contrl to work on my tv. OSO on screen display Magnavox, with vhs. I need the codesto get it work from the remote to the tv.
Manuals for all remotes available free here:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices
Hope that helps,
erch.
Magnavox tv i have an all in one remote control but i do nnt have the booklet. could you please send instrutions by mail, fax, or e-mail ,or phone .rather by fax it is the same as phone number which is 1 423 263 7206 thanks martha davis
how to get capation off my philips magnavox tv with remote can not make remote to go up or down . what buttons do i use help
SOURCE: need codes for the RC450 remote
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the
TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR
is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too..
now since I helped you.. check my band out...
www.myspace.com/jumpercablenj
SOURCE: remote codes
Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
SOURCE: Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
SOURCE: emerson jumbo remote
http://www.oldephartz.com/cterrian/manuals/JumboRemote.pdf THIS IS THE MANUAL FOR EMERSON JUMBO UNIVERSAL REMOTE WITH ALL THE CODES FOR ALL TVS VCR ETC...AND THEY REALLY WORK, I HAVE ONE AS WELL.
I have a one for all remote .I have a magnavox tv I need codes to get it to work from the remote to the tv
ihave a magnavox flat tv and need the codes so i can program a phillips universal remote the ones in the instructions do not work
philips universal
