SOURCE: price pfister faucet handle drops and turns off.
There is a price pfister little emblem under neath the handle. Use a but knife and pop that off. Once that is off there is a allen bolt in there. Tighten it up, put the emblem back and away you go
SOURCE: stuck spout
theres a little slide clip sometimes that sits inbetween the stem and faucet body look for that it may have one stopping your progress good luck
SOURCE: Kitchen Sink Single handle faucet ''pressure'' problem
By replacing the ceramic cartidge inside, however to replace it requires dismantling the tap (Mains off of course) and matching a new unit. Usually cheaper to buy a new tap.
SOURCE: Price pfister pull out kitchen faucet starting
Most likely it is under the label , it is normally put on with light adhesive. That is where the set screw is most cases. As far as leak goes, your on right track with 0 rings/gaskets. Be careful however, some time you can just get one at hardware store ( whole unit) already together almost as cheek as repairing this unless it is just a couple 0 rings.
Testimonial: "The set screw is indeed under the label. Thank you. Appreciate the tip to check out hardware stores too. for the whole assembly."
