Acer AL2216W LCD Monitor Logo
Posted on Mar 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer AL2216W's green light goes off completely when the computer is turned on. When I turn on the computer and monitor, there is green light on on/off button while an irritating Acer logo is showing up. Suddenly green light goes off and screen becomes blank. I do not even see an orange light. I have already tested my computer system and cables. They both work fine when plugged into another monitor (HP 2009m). Please tell me what the problem is and how it can be fixed.
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Mar 14, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3366082
Points
33650
You may have failure in the power supply due to bad caps, bad inverter circuits such as shorted transistors, transformers, bad lamps. You need to open it up and make some measurement, see example of failed ACER monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Hi. My Acer monitor AL2216W goes black just seconds after turning on. It's still on. Indicator light is green not amber or off. I keep it updated. It's a 2007. My pc a 2008 Del. Suggestions?
well you can test the monitor an any PC made, to see if the problem is the monitor .
easy no? just one simple test. I guess a VGA cable.
That old monitor uses CCFL back lamps. that most at dead now.
after 10 years of service they are DEAD. most are. now.
Green means not sleeping.
when PC goes offline the Monitor tells you ,
lost signal, going to sleep, no sync, or out of range.
all monitors made 2000 to now do that. every one.
the OSD dead. test.
so when you turn the monitor on , and push menu button
in under 5 seconds, does the monitor show the OSD screen.?
it will do that even if PC is turned off.
The OSD is the tiny brain in the monitor. on screen display.
if you test the monitor with a flash light when it goes black with
PC on.
and you see data, that means the CCLF are dead.
the do that, all do this now. dead, intermittent, stobes, or yellow for white screens. all do that at 20,000 hours. used.
click flashlight link here.
http://www.pcdied.com/monitors_and_screens/index.html
value if the monitor is $20 working , or $5 not.
so repairs are not all that econ101 giving this fact.
It wont turn on.
If the power light does not come on and it makes a screeching noise, most likely its broken. I would contact the manufacturor, in case some warranty left.
I have an Acer Monitor AL2216W and it will come on, the Acer name appears, then no signal and then the green light goes to orange. Is this the power supply or what?
It will go into sleep mode if it does not detect the signal from the PC. Try is with other PC first, also make sure the cable is seated properly.Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Here is the inside of your monitor:
http://s807.photobucket.com/albums/yy352/budm/ACER/Acer%20AL2216W/
My Acer AL2216W monitor this morning went blank. I woke up, turned on pc and went to sleep like an hour more, when I woke up, the screen was black and light orange, as usual, when pc is not used for a...
Go to Control Panel, (top right View Small Icons). Then look for Power Options. On this page, you'll have the option to leave the monitor on. You should also check "Advanced Power Options". Don't be afraid of the word, "Advanced." It only means "customizeable"
If your mouse isn't waking your monitor, try the keyboard's space bar. I found it works better than the mouse at waking a sleeping computer
I Have an ACER AL2216W LCD Monitor. Problem Screen comes on than seconds later cuts off. I get the green LED than it goes back to yellow or some times stays green but goes black screen
Does it do the same whan attached to another PC? Cables are good?
If it is monitor, you will need to check the caps and DC voltages first.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL2216W/
I have acer lcd al2216w on the lcd there is a green line comes between my screen it cant be remove i dont not how he comes please tel me what i do change a new lcd or what it can repairable or not
Hi there reinstall the display driver & then give a look. If you face same problem then its may problem with your display driver or in the monitor.
2answers
Purchased acer al2216w lcd monitor off ebay. turned it on and it had a vertical red line running from top to bottom near the right hand side.i started to copy a dvd and the screen went black with line...
The screen is bad, verticle lines, red or pink hue etc. is indicative of a bad screen or there maybe a problem with the data cable you are using to attach to the computer. Try another cable first, if the problem persists, the lcd panel is failing.
I have a acer AL2216w. it randomly shuts itself off
Replace the following capacitors:
3 pcs. - 220 microFarad - 25v
2 pcs. - 1000 microFarad - 25v
1 pc. - 2200 microFarad - 25v
Resolder the 2 inverter transformer's legs.
Roan
Triangle Tech Whiz
1helpful
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
