I have a kia amanti 2005 both heat up but i have no heat in the car. what can b the problem
"Both" what heat up? Both heated seats? If so, the heated seats are heated using electrical current. The cabin heat from the vents is heated from engine coolant. The car will need to be running several minutes before heat will start blowing from the vents. If once the engine temperature gauge gets up to normal you still are not getting heat from the vents and are certain you have the climate control settings correct to be requesting heat, you probably either have a blend door issue or an issue with the valve that allows coolant to circulate through the heater core. I'm assuming that your blower motor is working and you can feel air flow, just the air flow is not warm. If you are not getting air flow, then the blower speed controller may have failed, the blower motor may have failed, or some other issue is preventing power from getting to the blower motor.
