I have an HTC P3400i HANDSET with CellOne Prepaid Connection. Can any one assist me with the GPRS SETTINGS on this handset for BSNL cellone Prepaid connection
BSNLGPRS supports HTC windows based Mobile
Here is the Procedure to acessGPRS in your HTC
Go to Start- Settings > Connections >Connection >(Under internet settings select)Add a new modem connection
Enter a name for the connection:BSNL (you can type any name as you like) A modem(from the drop down list select)Cellular Name(GPRS)
(On the bottom of your screen select):Next
Access Point Name(APN):gprswest.cellone.in (gprwest or south depending on your location
Press : Next User name: Leave it blank Password: Leave it blank Domain: Leave it blank
In the bottom line press: Finish
(Make the connection BSNL default indicated by this sign @)
Here setting is finished.
TO BROWSE INTERNET . . . . Method 1
Press Start Internet Explorer Enter url/site name which you want to browse. Method 2
Under internet settings click on Manage existing connection.On your screen BSNL
(the name you had given will be shown)with the Joystick/Stylus(the stick coming along with the handsets).Tap and hold on the name i.e.BSNL,two sub menu will be displayed i.e.Delete and
Connect,click on Connect.
Please Observe the symbol of “E”or G .In HTC a small E comes out of E.
Note:Always keep only one connection setting i.e.BSNL and use method 1 as it is simple.If you have only one connection directly start browsing by method 1 as and when you want to browse the internet.
i am elamurugu. i connect the htc mobile with bsnl cellone GPRS as following method. ies
go to start
go to setting
go to connections
in this go to connections
go to gprs setting
go to Add a new modem connection
go to General Enter a name for these setting as: BSNLGPRS Setting
Select a modem as :CELLULAR LINE (GPRS)
Next
Access point name: GPRSSOUTH.CELLONE.IN [as i am tamilnadu bsnl south zone]
Next
User name: YOUR CELLONE NO 94**********
Password: YOUR CELLONE NO 94**********
Finish
go to Proxy setting
select [tick] This network connects to internet
select [tick] This network uses a proxy server to connect to the Internet
then go to Connection Setup
Select Operator
Country: India
Operator : BSNL
then OK
Do you want to continue?
Yes
finally RESTART YOUR DIVCE
say YES.
Afer restart you can now use bsnl gprs.You have note a symbol at top of your htc mobile as E or G.
If you have problem to connect bsnlgprs With this correct setting call cellone customer care about this or call me
After browsing a lot of sites and experimenting with the settings finally I was able to configure my HTC P3400i with Vodafone Live support without any help from the Vodafone customer care (who were very bad and rude when I called them for getting the setting). The settings is working fine for me in Bangalore. Hope this helps all who bought this phone and struggling for getting the GPRS setting for HTC P3400i.
Below is the step by step instruction: Step 1 Start->Settings->Connections->Tasks->Add a new modem connection:
Enter a name for the connection: <give any name>
Select a modem: Cellular Line(GPRS)
click next
Acess point name: portalnmms
User name: <blank> Password: <blank> Domain:* <blank>
Go to Advanced->TCP/IP select radio button "Use server-assigned IP address"
Go to Advanced->Servers select radio buttion "Use server-assigned address"
Step3: Start->Settings->Connections->Advanced In "Select which networks are automatically used"-> click the Select Networks Programs that automatically connect to the Internet should connect using: Select the Connection name which you configured in Step 1
Programs that automatically connect to a private network should connect using: Select the Connection name which you configured in Step 1
For BSNL South prepaid or post paid use following settings:
Start/ Settings/ Connections /GPRS
Connects to : Internet Access point: gprssouth.cellone.in
Leave other items blank.
Start/ Settings/ Connections /Proxy
Donot creat any proxy
You donot require any thing else. GPRS will work on your mobile and also in Internet share. Internet share works with cable and bluetooth. Browse on mobile or laptop !!! 9448834529
