Tip & How-To about Refrigerators
The efficiency of your refrigerator can be much better if you take the time to check out a few things before you buy or do a bit of maintenance on your refrigerator. The maintenance part I have covered in another tip, so I will just stick to the things that you can check when buying a new refrigerator in this tip.
Energy Star refrigerators will save you money. Look for a refrigerator rated with the energy star, when choosing a new model. Efficient refrigerators rated with the energy star are listed on the energy star website.
The style of the refrigerator will also make a difference in the refrigerator electric usage. A side-by-side refrigerator will use more energy then a top freezer model. The refrigerator electric usage is higher for those models with the two side-by side doors. If you look at the energy star list you can also see the energy kWh/year usage and see which models use the most electricity.
Some other things you can do so that your refrigerator work is less, includes checking the door seals, cleaning the condenser coils, checking the thermostat settings, and checking to see if you can turn off the door heaters if your refrigerator has them. Cracked or loose door seals will allow air to circulate outside the fridge, this uses more energy to keep the refrigerator cooling. Dirty condenser coils will cause the refrigerator compressor to work harder to cool the fridge. The door heaters also will make the refrigerator work harder to keep it cool inside. Adjusting the thermostats to 0- 5 degree F for the freezer and 36 -38 degrees F for the fridge side will keep your food fresh and still save energy.
Efficient refrigerators are great but they still need to be taken good care of by cleaning and servicing them regularly. Refrigerator electric is one of the biggest electric usages in most homes. Take some time to check over your refrigerator to help save some money on your electric bill.
http://www.fixya.com/support/r4326839-refrigerator_maintenance_tips
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4326731-new_refrigerator_size_or_refrigerator
http://www.fixya.com/support/r4326586-new_refrigerator_refrigerator_depth
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
http://www.fixya.com/support/r4020581-moving_refrigerator_best_way
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
