I need a owners manual to reprogram-the batteries died and when I replaced them, It lost the program
have a philips magnavox remote universal the rem 250 cfmp0018 cav#3
have codes needed need to know how to use them?
Hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
The link given my pywoodchuck didn't work for me. If you're still having problems try this link:
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1500115_AD_EN.pdf
It worked perfectly for my Samsung combination TV/DVD-VCR .
If your TV is a combo set don't use the TV codes only the combo codes.
Take care
Lost program need to know how to reset for tv maybe need codes for tv
phillips CL034 REMOTE tv sylvania
how to enter code
I have a orion tv need the code for a philips unviversal remote
I have a philip remote control universal cl034 and a daewoo tv how do I program the remote to the tv?
I need codes to my RCA television
after replacing the batteries the remote does not work Philips CL034
I do not have the manual to reprogram the remote
Philips Remote Control CL034
i replaced the batteries and then it stopped working
kjkuj
the batteries died in my universal remote and i lost the code list and now i cant use my remote
cfmp0018 cav#3 i need codes for sharp tv/vcrs
i put in new batteries and don't remember how to program it to work with my daewoo vcr, need codes and instructions
my remote stopped working, i have a sanyo tv but all the codes i found by my friend's list dont work, can anyone help?
