2003 Dodge Neon Logo
Posted on Mar 12, 2010
2003 Dodge Neon - fuse to dash and tail lights
2003 Dodge Neon - fuse to dash lights, tail lights, and door locks keeps blowing. I've replaced the fuse, and replaced the multi-switch, but that didn't solve the light/lock problem. Any suggestions?
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Mar 13, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
6732
Points
29
There could be a short somewhere in the wires
Dash and tail lights not working
the dash lights work off the tail light fuse, if all the fuses are good, you could have a bad light switch
1helpful
99 dodge no tail or dash lights keeps blowing fuses
the dash and tail lights are ran on the same fuse/curcit your shorting to ground somewhere along the lines. check for a broken bulb melted wiring or a broken wire
Tail light/dash light fuse keeps blowing
The dash lights and parking lights should be on two different fuses.
You may have a problem with the headlight switch, or something in the harness.
My door locks and ligh burn where can i find it
Look as you open the door on driverside on the dash you will see a fuse panel door. open the door and look inside the lid for the location of the fuse/relay controlling the door locks and the lights. Hope this will help you.
3answers
2002 neon no dash lights or tail lights. does have headlights and turn signals. the brake lights work also. the fuses are good.
then the problem lies near the dash because dash,tail,and license plate lights work on same circuit
1helpful
# 4 fuse blew out, replaced fuse and keeps blowing . dash lights do not work, license plate lights does not work, tail lights do not work, head lights work brake lights work . soon as taillights turn on...
I KNOW YOU HAVE AN ELECTRICAL SHORT.WAS AN ALARM INSTALLED OR ANY OTHER TYPE OF ACCESSORY? CHECK WITH DODGE TO FIND OUT ABOUT A RECALL.IF SOMETHING WAS INSTALLED, TAKE IT BACK THERE TO STRAIGHTEN IT OUT IF NOT HAVE A AUTO TECHNICIAN CHECK IT FOR YOU.
8helpful
4answers
2004 dodge neon fuse problem.
The dome tight is actually a combo fuse/light. If that light is burned out; 1 the locks won't work, and 2 the odometer will flash "FUSE" and 3 the "DOOR" warning light will stay on - try replacing the bulb. If it stays on with all the doors closed, more then likely one of the switches that are built into each of the door latches is not making the correct contact to shut off the dome light/dash light. The correct fix is to replace the defective latch. The other option is to just cut the wires that feel the switch inside the door - then the car will think that door is always closed and the lights will not come on when you open that door.
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
