You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-http://www.hirensbootcd.net/http://67.20.82.163/
Click start then type Device Manager in the little window. Go to networks adapters click the square or triangle beside it. Right click on the one that says wireless whithin the description and then click ENABLE if this does not work your wifi card is bad. You can purchase an aftermarket really cheap
You should be able to disconnect the external monitor, and then restart the computer to recover your defualt monitor.
If not see if oyu can move your mouse around enough to see the mouse on the second monitor, from there it depends on which operating system you have. That particular dell has XP...
So you would right click, go to properties, Settings tab, then click on the monitor you want to activate. Look for the check boxes, and click extend my windows desktop onto this monitor, then check the use this device as the primary monitor.
Hi hope this finds you well, go to control panel in the top right corner in the search box type mouse and you should get a several mouse option click on the change mouse settings, you will get another window with various mouse options then go to the pointer options tap, change the motion speed and hopefully that should solve your problem. good luck.
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-9400-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
You can pretty much use any wireless mouse. There is really no right or wrong just make sure drivers that come with the mouse support your Operating System and every mouse whether online or in store will tell you which OS do they support. Most newer ones will support XP,Vista and Windows 7. You can get them at Walmart, Targer, Best Buy or any other PC store. Hope this helps.
This could be a number of problems, one or many. Some things to consider
1)
You may be infected with a virus or a bunch of spyware. Do you have
Antivirus and antispyware utilities? I recommend AVG and Spybot.
2) You may have a bad hard drive. Try booting into safe mode and run a dskchk and/or defrag.
3)
You may have some faulty memory. Boot into safe mode and right click on
"My Computer" click properties and make sure you have the right amount
of RAM listed in this area. If not you may need to replace your memory.
Sounds like this may be a driver glitch. Try uninstalling the drivers for the quick play buttons from the device manager, then reboot. It will find the hardware an reinstall the drivers. If the problem persists, then disable the buttons either in the system bios or the device profile in the device manager.
