SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
SOURCE: My AEG dishwasher - Favorit no. 60870 sensorlogic
I don't have the answer - but mine has been doing this too. There's now a metalic/electical smell that has me worried so I've resorted to a basin of water and fairy liquid! Did you solve your problem?
SOURCE: Our AEG Favorit Sensorlogic dishwasher has had no power to it
if u just reinstalled mke sure you removed the blancking plug from the drain spigot . simple but happens a lot.
SOURCE: Our AEG Favorit Sensorlogic Turbodryis
i have the same problem, i have a machine that is 2005 model and it does not heat the water or dry in the end
