Who still carries mintek lcd tv parts? I need to replace the lcd display it is cracked.
SOURCE: Mintek TV codes
Still questions..no answers. The freezing seems to have gone away. I am still lookint for the remote codes.
SOURCE: Mintek LCD TV DTV-320-D buttons does not work
I have the same problems w/ my mintek 37 inch lcd and I have cut it off for days hoping that this will jumpstart it back to the tv mode so that we can at least get the enjoyment of watching it. The only thing it does is cut off/on the power. No other buttons work. I have called Mintek in CA and they offered no solutions except to mail the tv back.
SOURCE: I need remote code for Mintek LCD model 260
Use toshiba code 0156 that should turn on the mintek tv on
SOURCE: mintek cable in part
I believe ILO TV uses the same part.
Ebay seems to be the only place selling it. Here's 2 different sellers:
ILO 32HD TUNER BOARD DTV3218AT TDVS-H061P 601B1301 - eBay (item ...
eBay.com.my: ILO TUNER BOARD TDVS-H061P ILO-26HD LCD TV Parts ...
SOURCE: mintek 26in lcd tv
This unit has had a component failure on the main board.You can find parts for this model on e-bay. Have someone check the television for you and see if the failure is caused by minor failures. This could be from cold solder joints to bad capacitors. These are easy repairs. the way to do these repairs can be found on you tube,use the search engine to look for capacitor repair on lcd televisions and monitors.You can find parts for this television at e-bay.Put the make and model number of your television and the repair part number you are looking for. The search engine will bring all the parts available. You can also check this website for repair parts. http://www.discount-merchant.c/SearchResults.asp?Cat=&Search=PCB&RefineBy_Manufacturer=MINTEK I hope this information will help you with your problem.
I have a Mintek LCD display for sale. Contact me at dave{dot}jewell[at]juno{dot}com if you are interested.
