Have the first remote tested--most shops have a tester--point remote at it and press buttons and it reacts with a flash (the tester) and if remote tests good the problem could be with the remote receiver in the set
I'll have to go with Ironfist109 on their question. You can order a new remote on the website of the manufacturer, but you must get the Model number on the unit to determine what remote you need to order. The model number can be located on the back of the device. Once you have this, you can go the the RCA website, and go to support. From there you can order a new remote. Hope this helps!
You can purchase the remotes directly from Crimestopper or call them to direct you to a dealer near you. Their contact and order information can be found at this link:
I dont know what cd player you have! but you can order an orignal remote from www.remotes.com They may also tell you how to revive the old remote!
Please rate this free answer!
THANK YOU!
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote press and hold Select and red until the remote LED blinks twice type in 0 0 6 0 press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Its likely that the new new remote control has specific codes for the components it can operate. You should look to the remote manual or online source to find the code(s) for the DVD player you have. Without knowing the remote you purchased, its hard to locate codes for you.
