Hobart commercial machines are designed to run with commercial chemicals. There will either be an internal dispenser or an external unit supplied by the chemical supplier. Rinse aid is dispensed directly into the boiler. Detergent to the wash tank. The chemicals used are commercial strength so not required in the same quantity as domestics.
Hobart are commercial machines so require commercial chemicals. Companies like Johnson diverse and ecolab are the usual favourites, but wherever you buy your cleaning equipment from will have a brand they can sell you. Most companies also provide and setup automatic dispensers with their chemicals. Find a supplier and ask them what they can do for you
there are only two reasons that this would happen. 1. The burners are not adjusted correctly for optimal performance and they are running rich. Could be a gas pressure issue causing this or the orifice and fuel air adjustment needs checked. 2. The ventilation is not adequate. You need to measure the CO level if this is not vented to the outside. If it is then you need to make sure the flu is adequate and there are in temp inversion issues or room air causing backflow etc.
Simply determine what is not working, diagnose the problem, make correction or replace defective part and test operation. This is the best answer possible as there is no information as to what is wrong with the machine in your post.
