Question about Broderbund Computers & Internet
Physical purchase of printshop 2.0 professional. i installed and uninstalled the program several time. each time i try to select a project, i get the message that printshop needs to close and windows will inform you if a solution becomes available???????????????????? maybe a smart download would work? please help as i am really concerned! thank you!
  • 3 more comments
  • Anonymous Mar 12, 2010
    Physical purchase of printshop 2.0physical purchase of printshop 2.0 professional. i installed and uninstalled the program several time. each time i try to select a project, i get the message that printshop needs to close and windows will inform you if a solution becomes available???????????????????? maybe a smart download would WORK?
    windows 7, 4gb of ram and a dual core 2.5 ghz
    DID YOU GET MY PC DETAILS?
    MY PC IS WINDOWS 7, 4 GB RAM AND A DUAL CORE PROCESSOR AT 2.5 MHZ
  • shauqat May 11, 2010
    Hi
    Please can you tell me what the specification of your PC is? i.e. 2ghz, 4 GB RAM windows 7 etc etc
  • 561 Answers
Hi
The problem is that the print shop id for MAC not for windows 7, thats why it is not working
Researching myself and looking at the link above you will see there is no copy for windows available..........yet
I hope this has been useful
Posted on Mar 12, 2010
  • 6,487 Answers
Yes you can try to download a copy fro the internet and install this to your computer and then check if that will correct the problem. You can download it from this link.
http://mac.softpedia.com/get/Graphics/The-Print-Shop.shtml
6ya staff
SOURCE:
Installed printshop 2.0 on windows 7 professional. When I open the program and click to start a new project, it automatically pops up not responding. The computer screen turns white and locks up.
Does the Print Shop software say specifically it is compatible with windows 7 and up? if not it will not run, XP and earlier is not compatible with Windows 7 and up as I said..
Oct 26, 2016 | Computers & Internet
Installing print shop 23 on windows 8.1 get framework incompatibility error. what should i do?
I now have PrintShop 23.1 up and running on my Windows 8.1. This is what worked for me:
1. First, RIGHT CLICK on the Printshop icon on your desktop, select Properties, click on Compatibility, and make the selection to run the program in Compatibility Mode for Windows 8. Click Apply, then OK to exit.
2. Double click the Printshop icon on your desk top to open Printshop. If it works - great! However, if it does NOT work, it means the .NET framework required to run the program was uninstalled or corrupted by the Windows 8.1 upgrade and needs to be reinstalled, so please do the following.
3. From your Control Panel, select Programs and Features; in Programs and Features, uninstall Printshop. (You get to the Control Panel by clicking on Settings in your desktop popout taskbar, usually on the right side.) 4. Check to make sure the Microsoft .NET framework is also uninstalled. If not, attempt to uninstall. If you have recently gone to Windows 8.1, it may be partly or fully uninstalled because the 8.1 upgrade might have removed (or damaged) part of it. If it will not uninstall, don't worry! Proceed . . . 5. Follow this step even if you see no sign of the .NET framework in Programs and Features. It is almost certain that you have debris from it on your computer because this is a known problem, and Printshop will not reinstall unless the debris is removed. THEREFORE, clean your computer by using the Microsoft .NET Framework Cleanup Tool found at the following link:
.NET Framework Cleanup Tool http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
6. AFTER Printshop is once again installed, it will very likely NOT RUN unless you follow Step #1, above, to run it in Windows 8 Compatibility Mode.
Dec 20, 2013 | Broderbund The Print Shop 23 Deluxe
I can not uninstall ms office professional edition 2003 how will i uninstall this/
  • Click the Windows "Start" button and select "Control Panel."
  • 2 Double-click the "Add or Remove Programs" icon. This icon is labeled "Programs and Features" in Windows Vista and Windows 7.
  • 3 Single-click the "Microsoft Office Professional Edition 2003" item in the list of installed programs.
  • 4 Click the "Remove" button. If you use Windows Vista or Windows 7, click the "Uninstall" button near the top of the window instead.
  • 5 Click "Yes" when prompted to confirm your choice by Windows. The uninstallation process starts immediately.
  • or try some uninstaller tool .
    Sep 16, 2010 | Microsoft Computers & Internet
    I've installed Printshop 21 on my new computer. I
    Go to Control Panel,, Click Install New Hardware,, it will search for anything NEW, then ask you if you want it to automatically install the Drivers ! Click YES !
    Nov 14, 2017 | Broderbund Print Shop® 21 Pro Publisher...
    I cannot Instal Microsoft Office Professional 2007
    If  you have the installation disk, then uninstall the program by going to Add/Remove Programs, find Microsoft Office Professional 2007 and uninstall.  REBOOT your machine.  Make sure that it is uninstalled AFTER you reboot.  Sometimes Microsloth makes it difficult and darn near impossible to uninstall some programs so another uninstallation program is needed to remove all of the files from the registry.  I suggest "Perfect Uninstaller".  Then try installing again.  Hope this helps!  :+}
    Aug 01, 2009 | Microsoft Office Professional 2007 Full...
    Firefox will not open
    There is probably something wrong with your installation. Uninstalling firefox does not completely remove all traces unless you use Revo Uninstaller. Download this program, open it, select Firefox and uninstall it. When it asks if you want to delete registry entries or extra files, click select all then delete. Then try installing firefox again.
    Mar 13, 2009 | Mozilla Firefox
    Install Printshop V.5 on a computer using Vista
    The Printshop V5 program is supposed to run with Windows 98 or Me, therefore in order to use it with Vista or XP, you should open it using Compatibility mode--> Right click on the program icon--> properties-->Compatibility--> select Windows 98 or Windows Me
    Oct 31, 2008 | Computers & Internet
    I am fairly new to PCs. I recently purchased a Toshiba 205 and have Vista SP1.  I purchase Print Shop Delux 22 and started the installation process before I read the statement about don't start...
    Hello, Encore Software has released a patch to make Print Shop Deluxe 22 compatible on Windows Vista.
    Here is what they say here:
    http://support.encoreusa.com/kb.asp?id=571
    Problem I am looking for the Vista compatibility patch. Solution This Windows® Vista update will detect and repair The Print Shop® 22 and PrintMaster® 17 applications already installed on your computer. After applying this update The Print Shop® 22 and PrintMaster® 17 will operate normally on computers running Windows® Vista.
    Update Instructions
    1. Click the link located at the bottom of this page.
    Note: For Microsoft® Internet Explorer® the File download dialog may appear. Select Save this program to disk and click OK.
    2. Choose a location (e.g., the Desktop) and click Save. The download process will begin.
    3. When the download is complete, close the Download window.
    4. Locate and double-click the Broderbund_Print_Update.exe file that was downloaded to begin installing the update.
    5. Follow the onscreen instructions to complete the installation.
    Note: Depending on system or user account settings, you may encounter several interruptions during the installation process. If so, please click Continue or Allow in order to proceed.
    6. Launch and use The PrintShop® 22 or PrintMaster® 17.
    Click here to download Broderbund_Print_Update.exe (26.7 MB)
    Aug 21, 2008 | Computers & Internet
    I purchased printshop 2008, couldn't get it to work, returned it for another and the same thing happened. I get error code 2908. I bought it at staples and can't get my money back. I would appreciate it...
    Printshop takes an awful amount of memory. You might get it to work if you uninstall then do a clean install by making sure all other proggys are turned off while you are installing. You also need to clean up your startup programs. To make sure there are not too many all starting up . How many little icons do you have in the lower right hand corner and what are they for?
    Aug 10, 2008 | Computers & Internet
    Computers & Internet Logo
    3,827 people viewed this question
    Top Broderbund Computers & Internet Experts
    Peter Dragonetti
    Norman Worley
    Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
