Most any up to date TV shop should be able to help. Look for one that has some warranty authorization. These guys are up on new technology. Thanks for using fixya.
As a owner of a olevia who's company went out of my problem was TV will not turn on - think it may be a broken AC power panel. ... I cannot turn the power on or off, and NONE of the buttons work, nor ... For a while now when you accidentally unplug it from the wall or the power goes out it ... LED will flash continuously along with the volume going up to max. ..... It's a 37 inch. send it to a pro for repair
my olevia a 232 s12 2nd hand tv . gift from a relative wont power on .just had the blue light on.i was able to reset my 32 inch olevia by pressing and holding down the power button much like a computer to reboot.might work for you.
Replaced buy another tv.This tv can't be repair,if damages or broken to the LCD screen panel,only can be replacing a whole new LCD screen panel,will cost the same as a new tv.Damage tv tries take it aparts and savalges save parts for the same tv and model u going to buy.
the remote control code for DirecTV with Olevia 242T or 237T (37' or
42') model is 11610. this code will power on/off and volume up/down the
buttons on directv remote.
Or buy the Olevia RC-LRN remote control. go to olevia.com - accessories - remotes.
I have a 47 a 32 and a 37 inch olevia tv. Just bought the 37 because i havent had any probs with the others. Well recently i moved my 47 inch and had it plugged into an outlet that had a one of those one into three strips plugged into the outlet and my tv kept shutting off. So i plugged it into another outlet and it worked fine so do try another outlet.
I have a 32'' olevia 232v hdtv. I had a similar problem where the tv stays on less and less as you use it longer and it gets warmer. I called customer service and they explained that its most likely a problem with it is doesnt have enough power to run well. They said turn the TV off, then hit the master turn off switch in the lower back of the tv, then unplug everything from the TV, then unplug everything from the wall. Then after 3 or 4 hours, plug all back in and try again. Then they said if i still have a problem, call customer service at 1 866 9 olevia
