The problem you describe is very frequent. The fridge is getting the coldness from the freezer through a chant and the force of a motor fan Motor evaporator
Number: 173301 Substitution: 5300158289 part no. 26. So the build up of ice in the freezer is blocking the air pass thought and get the fridge cold. Also it may block the fan motor blades from rotating.
So the first you need to check is the heating element on the evaporator in the freezer department. This element might have burn out (and now is open circuit) and even f the defrost timer give instruction for start heating up the element is bad so the defrost is not performed. You just need to replace the heating element. Heater
Number: 178425-01Substitution:5317842502
Is the part no 1 in the diagram in this link.
If the heating element then the defrost timer is bad and does not give any instruction to the heater so you need to replace the defrost timer Defrost timer
Number: 174820 Substitution: 215846602 part no 40 in the following link
As you can see in above links and the one below you can find all the parts of your fridge which the diagrams can help you find them.
