Lenovo IdeaPad S10-42312CU Notebook Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my lenovo s10 screen broken i want it to replace
Hi my lenovo s10 screen broken i want it to b replaced in india..
where could i get service and replacement of it...
zul hafiz
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 28, 2014
zul hafiz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
351
Points
Lenovo s10-3c to display vlo labe 60 yes i format windos7
Tareq Bin Mostaq Mostaq
Level 3:
President:
  • Master 1,449 Answers
  • Posted on Mar 11, 2010
Master
Level 3:
President:
Answers
1449
Questions
31
Helped
614141
Points
3628
You contract your service bandor in your area.Thay can help you.
My lenovo S10-3t laptop won't start up. It has a black screen and the power button won't turn it on. It has a working charger that's plugged in. I already tried the unplug the battery and
For this kind of issue, please follow up the following steps to check:
1.confirm your Lenovo IdeaPad S10 ac adapter and battery connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includes two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:
http://www.ifitjams.com/lappower.htm
'blank sceen appear on my lenovo ideapad S10 but lenovo and the windows manage to appear after tunning it on and blank afterward
Hi licah,
It seems that your computer is not booting into windows properly at all.
You mentioned you see Lenovo and windows appear then the screen goes Blank afterwards, you can try to Boot directly into the Hard Drive manually just to get everything working or I mean Booting up again but this is a small shot from what you are experiencing but is also worth the try.
turn your S10 machine OFF then turn it back ON and keep on tapping f12 on the keyboard you should see Boot menu on the list Select HDD then press enter this should boot into the Hard Drive, if it does not then you may need to send the system back to Lenovo for a possible reinstallation of windows or on most time we also have the Hard Drive replaced in many cases.
I hope that this Helps.
Have a nice day,
mvincentc
My Lenovo Thinkpad SL 400 have a broken screen which flicks and show different colors with bertical striprs pls help
Hi kingston_koa,
Getting different colors with vertical strips are common effects of broken LCD/screen. Broken LCDs needed to be replaced. With this one, the best thing that I can recommend you is to contact Lenovo specially if your machine is still under warranty. They offer free repair and parts replacement depending on your warranty coverage.
Hope this will help you.
Thank you for using Fixya.
Broken LED
If its a broken LED you need to call LENOVO HARDWARE SUPPORT to replace the LCD
1 877 453 6686 option 2.thanks
How to use the sim card slot of Lenovo s10-3t ideapad in india. Is any provider providing such a provision
Hi. Maker sure upon ordering the computer at lenovo you requested for a 3G capability. The slot might be there but it is actually disabled. Enabling the 3G slot will need your laptop to be sent out at our repair department. If the 3G slot is enabled, all settings should come from you Insternet service provider.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
2answers
Laptop format
Just bought Lenovo S10 and so unlucky that window crashed. So have to restore my Lenovo S10 to factory settings. Can’t really find how ot restore to factory settings in Lenovo S10 from the User Manual. So check from google, after many many search, finally found the solution.
For Lenovo S10 to restore to factory settings follow the steps below:-
  • Turn off your Lenovo. (i mean shut down and make sure it’s power off)
  • Now press on the “One Key Recovery” key at the top of your Keyboard, your Lenovo S10 should boot up. Else hold down the “One Key Recovery” key until it boot up.
  • Now you may choose “Restore to factory settings” from the screen and proceed for the restoration.
    ** the restoration will first check if your windows files has been corrupted, if yes, then it will restore it to the original state and no restore is required. else it will continue with the restoration
14helpful
4answers
Replaced Lenovo s10-2 lcd and it won't recognize the samsung screen
Thanks for using FixYa.
Your Lenovo S10 will really not recognize the Samsung screen. Please use the OEM lcd so you won't experience compatibility issues. The S10 only takes OEM parts.
I hope this helps. Have a nice day.
- HotRatchet
4helpful
4answers
Lenovo s10 able to boot up but no display on screen
i have the same problem, but was able to solve it by taking out the battery and use the ac adapter only. i think s10-2 has some kind of sleep/wake up problem thats related to the battery.
I have four samsung hdd in warranty i want to replace plz give me service center at delhi and phone no
dear,
hope it will work
Head Office:
Samsung India Electronics Pvt. Ltd.
7th & 8th Floor, IFCI Tower
61, Nehru Place, New Delhi-110019
Tel: (91-11) 41511234
Fax: (91-11) 41608818/19
Contact Centre:
Toll Free No: 1800-110-011
(From MTNL/BSNL Lines)
Tel: 30308282 (Prefix Local STD Code)
The Official Samsung Website:http://www.samsung.com/in/
goodluck...
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
