The arm pulls in one direction.
If the force is towards the center of the disk, it's OK, it's the antiskating force. Set antiskating at 0, set the weight at 0gr, turn around the makeweight in order to set the tone arm parallel to the disk. With the antiskating at 0 the tone arm will stay parallel to the disk in the place you leave it. With the antiskating at any other position the tone arm will stay parallel to the disk going towards the center of the disk.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FiXya link: http://www.fixya.com/users/technical114
SOURCE: tone arm pulls back on my technics 1210s
your needles gone.or you've moved the tip by touching it.
try & twist the tip back straight.
A LITTLE TIP FOR YOU ....u should never wipe or touch the tip of a needle with your fingers coz the greese off your skin ***** them.blow it or use a little fine brush.
SOURCE: tone arm adjustment for 1200m3d
Reduce anti skate setting . Round knob with numbers on it at the base of the tonearm. Cheers john. styluscity.com
