MPS Multimedia QuickStudy Chemistry for PC Logo
Posted on Mar 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the difference of conservation of mass and energy
What are the conservation of mass and energy
Anonymous
Level 3:
President:
  • Master 1,194 Answers
  • Posted on Mar 11, 2010
Anonymous
Master
Level 3:
President:
Answers
1194
Questions
Helped
307815
Points
3666
The law of conservation of mass and energy states that mass and energy can neighther be created nor destroyed however it can be changed into one form to another.
1helpful
How can I fix my house to conserve energy?
Attach is an article published at AppraisalNewsCast, which explain 15 different ways to conserve energy in your home.
How do the values for total mass before and after reaction demonstrate the law of conservation of matter?
  1. The law of conservation of mass, or principle of mass conservation, states that for any system closed to all transfers of matter and energy (both of which have mass), the mass of the system must remain constant over time, as system mass cannot change quantity if it is not added or removed."
In other words matter cannot be created or destroyed, only converted, into heat, energy, work, or other matter.
If your system is not closed (it probably isn't) and mass does not remain equal, then it is most likely that energy was gained or lost by the system. This most likely was in the form of heat.
You will need a pretty good scales to detect this though, as a tiny amount of matter = a huge amount of energy
Why does the scanner keep turning off after 30 minutes with a red light? We have to keep manually turning it off and on.
Some kodak of the i2000 series abide by different energy conservation standards. You can increase both power off \ sleep settings to 240 (4 hours), maximum. Unfortunately when the newer energy conserv's go have to be power cycled to resurrect. I have a tiny text script I can send that will make the 2400 never turn off I'm just not around my PC right now. Stay tuned!
1helpful
Simple pendulum
When giving physical quantities you cannot omit the units. (an angle of 10 what). You cannot solve the problem fully because you are missing the length of the pendulum.
You cannot use any kinematic relations because the expression of the period depends on the assumption that angles of rotation remain small.
You will have to use the energy conservation principle. Assuming that the mass was released with 0 initial kinetic energy, the kinetic energy at the lower point (angle 10 degrees) is equal to the change in potential energy between the release point and the point where the mass is.
(1/2)mv^2=delta Ep= Ep(30 deg)-Ep(10 deg)
Once you calculate the potential energy (see screen capture) difference you will see that it is proportional to m*g, so the mass will cancel out.
fa4a24ac-c4c2-48d5-9f73-9560389da196.pngYour turn: Calculate the potential energy difference between the positions at 30 deg and 10 deg, equate the result with the kinetic energy and solve for v^2, and hence for v the tangential velocity.
Wireless disconnect in sleep mode?
I think that is normal to conserve energy. There are times when it will take the network connections down to conserve energy.
If it is a problem you can always increase the time on the sleep mode or set it to NEVER.
3answers
What is first alww of thermodynamics
The first law of thermodynamics distinguishes between two kinds of physical process, namely energy transfer as work, and energy transfer as heat. It tells how this shows the existence of a mathematical quantity called the internal energy of a system. The internal energy obeys the principle of conservation of energy but work and heat are not defined as separately conserved quantities. Equivalently, the first law of thermodynamics states that perpetual motion machines of the first kind are impossible.
1helpful
2answers
How many quarts of oil for an lexus 2002 rx 300 consume
the 1MZFE engines sump capacity is designated in the back of the owners manual.
(4.5 US quarts)
What is conservation of mass and energy and give example
In fact there are 2 different conservation laws: conservation of mass and conservation of energy. Of course in a chemical or any other physical process these 2 laws will hold!
Conservation of mass: the mass of a closed (isolated system) system will remain constant over time.
Conservation of energy: total amount of energy in an closed system remains constant over time
Furthermore if we look into the relativity theory, it states that in fact mass and energy are two names for the same thing (the equivalence principle of mass and energy), neither one "appears" without the other.
Example: an iron nail left in a cup of water until it turns entirely to rust. A precise scale will register a change in mass. The energy will appear as heat, which will be lost to the environment so because of the conservation law you will see a loss in the mass of the system.
Top MPS Multimedia Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a MPS Multimedia Computer and Internet Expert? Answer questions, earn points and help others
