A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so,
please see this link for further info and a simple fix that may help.
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON). Unfortunately if this is the case, believe that you may find that the estimated cost of repair may exceed the current value of the camera.
