Verizon Razr V3 with locked screen. Verizon screen, white screen then Motorola screen with the words Bootloader USB INIT. The only way I can get to turn off is to remove battery. Can this be fixed?
Depending on how many modifications, hacks, or customizations that you perform on your Motorola RAZR V3 phone, there may be situations where the phone becomes unusable or completely locks up. I have had visitors to the site report not being able to delete ring tones, text messages, or have other strange behaviors with their Motorola RAZR V3 phone.
If this is you situation, then you may be interested in performing a master reset (or “hard reset”) on your phone. The master reset will effectively restore your phone back to the factory condition, inclusive of all settings. Be warned, any data that you have not backed up, photos you have not transferred, calendar settings, or messages you have not saved will be lost! Make sure you do this first, if possible!
Here is how you perform a Master Reset on the Motorola RAZR V3: 1. Open your phone up and go to “Settings” 2. Next go to the selection for “Initial Setup” 3. Next go to the selection for “Master Clear” 4. Then select to confirm the option. 5. Now enter the security code which should be “000000” 6. Finally press select or ok and the phone will reset itself to the factory condition
Congratulation you have performed a “hard reset”, “hard reboot”, or “master reset” on your Motorola V3 RAZR and it should return to normal operating mode!
Trackbacks that led to this post: hard reset motorolla razr v3 hard reset razr phone wii master reset hard reboot motorazr how to hard reset a razor v3 master reset code for motorola v3 master reset code razr v3 master reset for v3 via pc master reset motorola razr 2 master reset v3 razr with white screen motorola v3m master reset p2k commander razor master reset razr 3 and how to reset razr master reset ebay razr master reset password razr master restart razr screen master reset reset razr reset razr to factory reset razr v3 to factory v3 hard reset razr v3 razr reset hard boot
have you set your voicemail box up yet? maybe thats your problem...if you cant get it to work call customer service from a different phone so a customer representative can help you with your problem.
You can take the phone to a mobile center and have it unlock or try online at unlockitnow.com or mobile2mobile.net, this process usually take about 12-24hrs to complete....just provide your IMEI #....
I had a problem very similar to this with my Razr but my service was through Verizon. I took it into a Verizon store and they thought that a software upgrade would fix the problem. It didn't. Fortunately, the phone was still under warranty and they ended up replacing the phone.
If you are under warranty, get a replacement. In my experience, this problem will get worse. If you are out of warranty (older than 1 yr), you may be able to argue for a refurbished replacement at no cost - ATT/Cingular has been far more accommodating than Verizon. Or activate a different phone - I had my old LG and used it instead until I am eligible for a my new one, and it WON'T be a RAZR! Good luck.
