The oval burner knob(and operating instruction manual)specifiy a flame range exactly the same as the other burners: from "High to Low". But, there is little difference in flame height between high and low. Compared to the other burners the oval burner provides a flame of "low" and one setting above low. The GE repairman could not adjust it higher without causing the "low" setting to blow out and leak un-ignited gas.
How can this be repaired? Does it need a new burner assembly?
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
The smoothtop burners are not regulating anymore...they stay on high....or very low...no medium range so it is impossible to regulate temperature
