It sounds like you've already done a lot of troubleshooting, but here are a few more things to check:
Spark Plug: Check the spark plug for any visible damage or deposits, replace if needed. Make sure it is tightened properly and there is a strong spark when cranking the engine.
Fuel Filter: Check the fuel filter for any clogs or debris, replace if needed.
Air Filter: Check the air filter for any damage or clogs, replace if needed. A dirty air filter can restrict air flow to the engine and cause it to stall.
Vacuum Leaks: Check for any vacuum leaks in the fuel system, this can cause the engine to run poorly and stall.
Governor System: The governor system regulates the speed of the engine. If it's not functioning properly, the engine may stall. Check the governor arm, linkages, and springs for any damage or looseness.
Ignition System: Check the ignition system, including the ignition coil and ignition module, for any signs of damage or wear. Replace if necessary.
Fuel Pump: Check the fuel pump for proper operation, the fuel pump may be failing and not delivering enough fuel to the engine.
These are just a few possibilities, and it's best to consult the owner's manual or a professional mechanic to diagnose and repair the issue.
Idle adjustment on back of carb near front of bike. As stated in another post. The bike NEEDS to idle at 1000 - 1200 rpm for proper oil flow.Anything less and you could starve the bike of proper oil circulation and damage the motor.
Sure can. To do it properly, you should perform a smoke test after each adjustment. This requires a special tool. This may be why noone has answered your question yet. There is a band on the left side of the burner that can be opened to allow more air in. The flame should be bright orange/yellow. And again, perform a smoke test after you adjust it.
