Computers & Internet Logo
Posted on Mar 10, 2010
Acer L100 will not turn on the blue light keeps flashing but pc will not turn on
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 30, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8566
Points
This PC has a design fault, with inadequate cooling.
I managed to squeeze in 2 fans side by side, where there is normally only one fitted in the case. It requires cutting away some metal so not a simple fix but it now keeps the case internal temperature down well within a safe working temp.
Unfortunately I didn't implement this fix soon enough, and ran it too hot for too long causing a motherboard fault that sometimes trips out the power supply when you try to boot up. Ho hum.
Anonymous
Level 1:
  • Contributor 51 Answers
  • Posted on Mar 11, 2010
Anonymous
Contributor
Level 1:
Answers
51
Questions
0
Helped
32799
Points
77
Does it beep at all?
If so, read up on beep codes:
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
1 Related Answer
Anonymous
  • 10 Answers
  • Posted on Aug 25, 2009
SOURCE: acer L100 wont power up
bad PSU
Testimonial: "thanks for that about the psu, but i have been told by a local pc repair guy that psu's are as good as rockin horse poo to get cos the L100 is mini?"
The blue power light and the blue and red battery lights keep flashing and won't stop Why?
Sounds like the battery itself is going bad and needs to be replaced. The blinking lights are a code that you can find at the OEM website and it will tell you exactly what is going on..
My aspire L100 will not boot. When on button pressed blue light comes on and then goes off straight away and fan starts Ok but nothing else
You may need a new power supply....also check your internal fans to make sure they are spinning. Make sure memory is seated properly. Motherboard may also be in question. Try unplugging letting it sit for a few then plugging back in.
My Acer Aspire L100 PC Desktop won't start.. when i press power button it only flash LED light jus one time but no HDD sound or CDROM working sound. only CPU fan works thas bout it...Any help? pls
Do you see anything on the screen?
Try the following things:
  1. Try starting the computer with only the battery
  2. Remove the battery and try booting with only the power adapter
  3. Try removing and replacing your memory
Could be a bad power supply or bad battery. After you try the above steps, report your results.
2answers
Forgot Acer Aspire L100 BIOS master password. Used "cmospwd /k" to remove password, but power was cut accidentally. Now, machine starts POST (keyboard lights flash), but there is no display.
In cas eof forgot password of bios you must follow the following steps
  • open the cabinet and look for the bios on the corner
  • there u would find a pin which is fixed on the side of BIOS take the pin out and put it in the next two pins and again fix it at the original p
Now your BIOS password is reset and u can access your pc
Flashing Light
maybe that light indicating the reading of the hdd.
2helpful
Samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
No desktop view
The L100 series has a bad reputation for overheating. I worked on a friends and had to reseat the heatsink for the processor with new thremal paste to keep it running
I own a acer aspire L100
You have a PCI slot in the computer. If it's available, you can get a 256MB or 512MB PCI video card. Anything you get would be an improvement to the internal card you have. Just familiarize yourself with your monitor's inputs - DVI (the white connector) or VGA (the blue connector).
Here are some options:
http://www.tigerdirect.com/applications/category/category_slc.asp?Recs=10&Nav=|c:1603|&Sort=3
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
