Konica Minolta magicolor 2300DL Laser Printer Logo
Posted on Mar 10, 2010
Can I reset the drum counter for a Konica Minolta 2300?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1320
Points
The best way to reset the counter is to replace the fuse on the underside of the printer drum. That is not hard to do, but you have to be careful not to break the plastic tabs holding the original fuse in place.
Installed new drums in konica minolta bizhubpress c6000 drum counter did not reset automatically. How do I reset them?
service mode then clear the counters, should have done it before installing the drums.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica minolta 185 m2
Clear the counters for drum and developer, Replace the drum and developer, run required process, done, Do not reset without replacing because copier uses the counter if you reset without replace code and image problems will begin. Because copier will think drum and developer are new when in fact there are not and voltages set for new will be working on old stuff.
Monolta izhub 362 hwo to reset drum counter
Bh 362 is the upgrade of Bh 200, 250 and 350 and on that model you need change drum and developer together. The drum counter message can be reset in service mode by a qualified tech after replacing those parts.
Reset konica drum counter
has it been replaced???????????????????????/
Has the drum been replaced? If not reset code for drum without replacing the drum is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items, then the copier will adjust certain voltages to certain items such as the drum as those it is new because you reset the counters when in fact the drum is old and so you might be codes and image problems.
1helpful
2answers
Error replace drum unit konica minolta 190
The photo sensitive organic material on the Toner Drum have a life and the counter helps to track it.
Konica minolta di3010 how can i reset drum unit?
You replace the drum and developer. Pior to that you clear counters and run the require procedures after because if you reset your drum unit without replacing it the codes will begin to show up the copier works on the counters when you clear it then the copier thinks the drum is new an set voltages as required since it is not new then you get problems . Replace the drum, cleaning blade and developer and do it right!!!!!
Change pc drum konica minolta di3010f
the drum, cleaning blade and developer are all replaced at the same time, no but you can damage the drum and or sensor
1helpful
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
