Question about Jura Capresso Impressa X7 Espresso Machine
Our Jura x7 is showing Malfunction 4. What does this mean
  • Anonymous Mar 23, 2014
    Error 4 jura x7
  • 3 Answers
Hi Error 4 is the following fault :STEAM: Temperature sensor notify “value above tolerance” I think only a trained engineer could fix this unfortunately. Hope it helps though. Alison
Posted on Mar 10, 2010
Testimonial: "Thanks Alison, will get tech out since there is nothing we can do. Thanks for the info. Jim"
Hi, had the same issue and it seems to be that the most common reason is the temperature sensr (omega sensor) on top of the Thermoblock. I have a technical background and could easily resolve the problem within the X7. Remove backplane and slide away and remove the side cover where normally the water tank is.
on the left bottom you see the Thermoblock and on top a small round ThermoSensor (called omegasensor). Replaced this sensor and it all worked fine again, In case it still does not work, have also a look to the other thermoblock on the right bottom. There is the sensor of the T-Block. little bit more difficult to reach, but as long you do not lose your screw then it is do-able. If you hesitate then of course let a specialist do it for you. When it are only the Thermo sensors then the cost is low and not difficult to repair for the specialist.
Posted on Jun 15, 2012
SOURCE:
Jura Impressa x7. What is cause of malfunction 8 error?
Pretty unit...
I do love my coffee...!
Judging by the number of positive hits, diagrams... & retail parts houses... you may not have done too badly.
Check out the search page posted at the bottom
http://www.bing.com/search?q=jura+impressa+x7+parts&form=PRDLC1&src=IE11TR&pc=EUPP_DCTE
Capresso Impressa Replacement Parts
Jura Capresso Parts Capresso Parts
Mar 24, 2016 | Coffee Makers & Espresso Machines
Jura impressa x7 keep getting report fill water tank
make sure the water tank is full! there is a small float in the tank that moves up and down near the bottom, make sure this is up and not stuck down.
Feb 05, 2014 | Capresso Jura Impressa X7 220v
Error code 15 on a jura giga professional x7 coffee machine
Dear sir ,
Please help me, Now my coffee machine Jura GiGa X7 Professional , When i start turn on machine maybe 15 second it turn off by it self.
Jan 11, 2014 | Coffee Makers & Espresso Machines
Jura X9 coffee machine is stuck in the heating up mode. How do I fix it?
Either there is issue with the Sensor or the Thermoblock. you'll have to replace either of these.
Oct 02, 2013 | Jura Capresso Impressa X7 Espresso Machine
My jura X7 system is rinsing with milk. When pressing the rinse button, the machine is drawing milk to rinse instead of water??
The milk tubes should be submersed into water with a milk cleaning agent. sounds like you've left the milk tubes drawing from the fridge with milk in it.
Bean to cup cleaning
Aug 15, 2013 | Jura Capresso Impressa X7 Espresso Machine
Jura impressa x7 does not rinse and coffee does not come out. I do get steam for froth etc
Jura x7 coffee machines are older models in the coffee machine range. It may simply require a full system clean, using jura cleaning tablets, or more likely a service. Bean to cup machines should really be serviced every year to 18 months depending on usage.
We can put you in touch with a Jura engineer if you need one, contact me here Denby Dale Coffee
Oct 19, 2012 | Jura Capresso Impressa S90 Espresso...
Our Jura coffee machine S9 model has error message Malfunction 4 appearing, have turned machine off from power swith and left off for 30 secs, still has same error message.
Hi, Printed below is the fault for Error 4:
I hope this helps.
Alison, Uno Coffee Company
Feb 11, 2010 | Coffee Makers & Espresso Machines
Jura Capresso Impressa X7 Espresso Machine Logo
2,540 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
