Frigidaire Front end loader washer model LTF2140ES3 will drain but will not do final spin. Have check all hoses and they are clean. Help?
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle to advance to the spin cycle. When the machine works except advancing to the spin cycle, it signifies that this auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to fix the washer.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the wires from its terminals then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
