Remove the card and battery. Clean the battery contacts inside camera with a cotton swab lightly dampened with rubbing alcohol. Be sure battery is charged. Press all buttons on camera. Insert card and then the battery. See if it works. If you can now get into the setup menu, you can do a reset from the menu.
If you are looking for drivers in that CD, click Panasonic Support and check drivers list of DMC-FX01 at bottom of page. and if you need Software CD, please contact nearest Panasonic service center.
hi sir.. to fix the problem please restore the factory setting.. it will be in setting> restore factory setting> then restart..it fix the problem.. thank's sir.. please rate it.
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
same problem with ours, only 7 months old. We returned to the seller under warranty, and they fixed the problem FOC. They stated "lens adjustment" on the repair invoice. I think these machines are not as sturdy as we are led to believe, and the slightest knock or bump sends them a bit squew wiffy!
You can call
(044) 22352501 check this website for frequent issues with DMC FX01's http://panasonic.jp/support/global/cs/dsc/faq/fx01/answer.html#q1 My only direct suggestion is to take the battery out for a few minutes and then replace it. Failing that, try running the camera with charger without battery installed.
