Electrical Supplies Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kipor power with a fault code p-03 and it shuts off after a cople of secends . what could be the problem.i found in a forum that the posible cause could de the avr put i do not no were its located or if this could be my problem
thesnooper
Level 3:
Master:
  • Master 342 Answers
  • Posted on Apr 04, 2010
thesnooper
Master
Level 3:
Master:
Answers
342
Questions
0
Helped
96660
Points
1038
Press and hold the function button turn on the ignition and hold until it ges into test mode should display something like ph 2 then start it up and test the output voltage and wether or not it produces power correctly. if it does test the output voltage with a multimeter to confirm the output is the same as displayed on the machine if not remove the control panel and adjust the trim pot on the rear of the display panel until it displays correctly,
if not it could be the carbon brushes in the altenator or the avr which is a black box bolted to the frame
3answers
I HAVE A KIPOR 7000 TD generator suddenly stops and shows E-04
Usually when errors come up, you can reference the product manual to find out the specific meaning of your error. So, please do this first. If you don't have the manual, please call the manufacturer of your product (ie Kipor) in order to gain information of the meaning. In the mean time, I would advise to shut down the generator or at least use a air volatility detector until you determine the meaning of the error.
Thank you.
2answers
What is the p03 code for kipor generator
P01 oil pressure alarm
P02 frequency alarm
P03 voltage alarm
P04 unit overload alarm
P05 start-up fault alarm
P06 emergency shutdown alarm
P07 charging fault alarm
P08 unit overheating alarm PRE-H unit preheating instruction START unit start-up instruction.
Cummins generator and Perkins generator at website: www.dieselgeneratortech.com. power range is 20kw to 3000kw.
I have a kipor KDE12STA generator When it is started it shows the error code E-04 overload After a few moments the moter switched off What could thjr fauilt be and what could be a way reset or fix the...
Give you some suggestion, hope can be helpful for you.
Here is some basic principles for troubleshooting generator faults:
1. Check outside of generator firstly then inside
In the case of generator failure, the possible fault locations outside the electronic control system should be checked firstly. This can avoid a fault that is not related to the electronic control system, but make complex, time-consuming and laborious checking on the sensors, computers, actuators and circuits of the system. The real fault may be easier to find but can not be found.
2. Code priority
Electronic control system generally has fault self-diagnosis function. When some fault occurs in the electronic control system, the fault self-diagnosis system will immediately monitor the fault, and alarm or prompt the operator through warning lights such as "monitoring engine". At the same time, the fault information is stored in code. For some faults, the fault code should be read according to the method provided by the manufacturer before the fault self-diagnosis system is checked, and the fault location indicated by the code should be checked and eliminated. After the failure code refers to the elimination of the fault, if the engine failure phenomenon has not been eliminated, or no fault code output is started, then the possible fault location of the engine is checked.
dsc01081_??-gchmaamodmqy1czm0regslps-1-2.jpg https://www.dieselgeneratortech.com/generator
My Kipor KDE 6700 TA Generator starts, runs for and few seconds and shuts down with a P-03 L-H Volt Fault Light coming on. What can i do to get it working again?
Dear my friend, where the Kipor generator do you buy? Maybe you can contact your supplier, they should know for your question. In generally, there is after-sales ervice .
More support, maybe you can visit website for reference: www.dieselgeneratortech.com
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Why unit keeps shutting down after it starts.
Your question is general without specific details. Any one of many things will cause your generator engine to stop running.
Is this question about a Kipor KDE5000TA? If so, your generator is powered by a diesel engine. There are safety shut downs built into the generator to protect the generator head and engine. Do you have any fault codes showing on your control panel display screen? (Trouble codes P-01 through P-05 will be displayed if there's a detected fault)
If you have no fault codes, then you likely have a fuel problem. Do the obvious:
  1. Visually check the fuel level in your tank. DO NOT rely on your fuel gauge. It may be stuck or otherwise not working.
  2. If you have fuel, check your fuel filter. It may be clogged. If your fuel filter is good, you may have water contamination.
  3. Drain your tank and refill with fresh #2 diesel fuel. I use "Diesel 911" with a biocide to prevent water contamination and bacteria growth in my fuel.
  4. Make certain your fuel oil supply and return lines are clear, not leaking, and the fittings are tight.
I know I'm shotgunning, peppering the target. However, I don't have enough information to zero in on a specific area where the problem could be. Good luck!
I have generator kipor kde19sta3 when we start then generator after 1 or 2 minutes generator will automatically off and show the fault p 03 so plzzz tell me about p 03 fault thankx
Sounds like an overload on the board. Be sure you're not drawing more amperage out of the plugs on the front of the unit than is listed (typically 12.5 or 20 amps is the limit). If you try and draw more or a surge on the appliance happens during startup, you may end up having to use the 240 volt plug and direct that into a distribution panel to get the 110v unhindered by the plug limitations.
Top Kipor Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Jay Finke
Jay Finke
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
