My Nikon LS-30 starts up, the G3 to which it is connected boots fine as well.
If you launch System Profiler, in Tiger, it will recognize the Coolscan III scanner attached to the computer through the PCI SCSI card installed in the computer.
Then during normal operation there would happen a Kernel Panic, the problem got more and more frequent, and now when I try to start the scanning soft (be it Vuescan or SilverFast) the computer has a kernel panic.
I've changed cables, changed SCSI port, SCSI cards, turned the termination ON and OFF, tried different Macs, different versions of Vuescan and SF.
Any ideas whatelse can I try?
SOURCE: Nikon Scan doesn't recognize scanner
You need to check that the ASPI drivers are loaded, otherwise it will not work. The LS-2000 works with Adaptec ASPI v4.71. These drivers do not come with the Nikon product.
SOURCE: PC (Dell) won'r recognize scanner (nikon ls 2000)
This is a problem with SCSI bus speed too fast for the legacy device. The recommended SCSI controller is the Adaptec 2906, which will recognize legacy devices and slow the bus speed for them.
You also need an older ASPI driver set, version 4.70 available from Adaptec at http://www.adaptec.com/en-US/speed/software_pc/aspi/aspi_v470_exe.htm
Before you install the 4.70 version you need to be sure to remove any newer versions of these files:
Normal 0 false false false MicrosoftInternetExplorer4
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}ASPI32.SYS
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WOWPOST.EXE
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WINASPI.DLL
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}WNASPI32.DLL
These files may be found in WindowsSystem or WindowsSystem32. In order to delete them, you will need to restart your PC in Safe Mode. Once they are gone, restart your computer normally and run the ASPIINST.EXE program which was extracted by running the file downloaded from Adaptec.
Finally, you need Nikon Scan 3.1.2 for the LS-2000, available at http://support.nikontech.com/app/answers/detail/a_id/81
SOURCE: I would like to connect my old SCSI coolscan iii
If your macbook doesn't have the correct SCSI card (SCSI II - d-sub mini 50 pin x2 connector) installed, you aren't going to be able to do this. You will need to find this SCSI card and install it in a computer that will accept it.
Rich
Testimonial: "Thanks for prompt and clarifying answer!"
