SOURCE: hot shoe loose
Canon typically hides the screws under the metal plate on the shoe itself. You have to free it at the front and slide it back to get access to the screws holding the shoe
SOURCE: Replacement battery for Yellow Powered Corvette
I just checked and found one for fisher price cars on amazon...I'm not sure if it's what you want or need (no kids, never saw that battery) but I'll bet it's what you need! To get there, I typed in 12v batteries. Amazon was listed there as a source.
SOURCE: Need 12 V Battery- Corvette Yellow purchased at Toys R Us
Personally I'd buy another brand of 12 volt and just change the ends to fit in car. Measure dimensions of original.
SOURCE: 2005 Mountaineer Rear Emergency Brake Shoes stuck on inside Rotor
Well, you will have to wiggle and pry the rotor until it comes off. I just did this on a 2003 mountaineer and it was a bear. At least one side was very hard. It turned out the rotor inside was so bad that the shoes could not get past a lip on the outer edge of the parking brake effective surface. I had to pry and hit until it came off. Once removed I noticed that the shoes were shot, I mean, the braking material was completely gone. This is where the fun began. Removed the springs and removed the hold down clips. The hold down clips were stretched and were not effective by the way. Removing the shoes was not too bad. Installing the new ones is difficult as the wheel hub is in the way. Carefully install the springs and adjuster. Once you get past that then you have to deal with the hold down clips. It happens that the top pin where the clips attaches to is fairly accessible from behind so you can support it while you install the hold down clip. Again, it is doable but very difficult as the hub is in the way and the room is barely enough. Once you do the upper, the bottom one is the bear, the hole to access the pin from behind happens to be underneath the CV joint and it is not easily visible. I had the worst time installing this clip. If you do not then the shoes will rub against the rotor. Not good. Anyways, it is not easy, I do not know what they were thinking with this system. Removing the nut in the center will only allow you to remove the cv joint, you will have to deal with the wheel bearing if you want to remove the hub. Good luck, and I hope this helped.
SOURCE: I'm looking for replacement knobs for my Jenn Air
I agree...the knobs are a POS.......redesign needs to happen....
Checks
Cause
Case (7)
The rear band anchor pin is broken or the pin is not positioned.
Center Support (640)
Leaking at the case, or the support is broken.
Center Support Seal (639)
Leaking
Center Support Bolt (25)
The bolt is loose or broken.
The feed hole is blocked.
Rear Band (657)
Broken, worn, or not anchored
Rear Band Apply Pin (73)
The pin is too short or the pin is binding in the case.
Piston (65)
Binding in the case
Seal (66)
Leaking, damaged, or worn
Gasket (63)
Damaged or displaced
Cover (62)
Damaged
Bolts (61)
Broken, loose, or missing
Checkball
Missing
Fluid Pressure
Too low
Direct Clutch Components
Reaction Plates (618)
The splines are worn.
Friction Plates (611)
The splines or the friction are worn.
Spring Assembly (607)
Jammed
Housing (623)
Cracked
Piston (619)
Leaking
Seal (620, 621, 622)
Leaking
Ball Check
Leaking
Porosity, damage, misalignment
Channel Plate and Gasket, and Valve Body, Gaskets, and Channel Plate
Porosity, fluid leak across the channels, misalignment, damage, or fluid restriction
Low and Reverse Band and Servo
No apply or slipping
Servo Piston (69)
Broken or binding
Servo Piston Seals (71, 72)
Leaking
Servo Pin (67) and Springs (66, 68)
Binding
Servo Cover (73)
Broken, loose, or leaking
Low and Reverse Band (111)
Broken, worn, or out of position
Anchor Pin (64)
Broken
Fluid Feed Tubes (83)
Broken, bent, or plugged
Missing or leaking seal rings
Transmission Case (1)
Porosity, fluid leak, or restriction
Shift Linkage
Disconnected or misaligned
Manual Valve (800) and Link (802)
#1 Checkball
Missing, no low band fluid
Fluid Level
Low
Fluid Pressure
Low
Refer to High or Low Line Pressure .
suggest you take to an ASE certified transmission repair facility !
Servo Piston (69)
Broken or binding
Leaking
Binding
Servo Cover (73)
Anchor Pin (64)
Broken
Shift Linkage
#1 Checkball
Fluid Level
Low
Fluid Pressure
Low
Most likely your trans needs to be rebuilt !
to
Fig. Fig. 1: Clutch release bearing - 1990 Colt hatchback and sedan w/ 1.6L engine, 1990 Colt Wagon w/1.8L engine, and 1990-93 Vista
Fig. Fig. 2: Clutch driven and drive discs - 1990-93 all models
Fig. Fig. 3: Clutch release bearing - 1990 Colt Wagon w/1.5L engine, 1991-92 Colt hatchback and sedan w/4-speed and 1993 Colt hatchback and sedan w/1.8L engine
