I am not sure what type of pressure switch you are looking for but if it is a low or high pressure switch for the air conditioning, then you can purchase that through a parts store.
The adjusting screw is underneath the saw. You shouldn't monkey with the rings unless you know what you're doing and if you know enough to change rings, then why would you need the manual? Are you looking for part numbers for the rings? The upper ring is 1118 034 3001 and the lower one is 1113 034 3006. DO NOT GET THEM MIXED UP! You will destroy the engine REAL quick.
This is a 30 Ton Hi Efficiency Gemini series unit from carrier
you can matched to either of these air handlers.
40RM028
40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size
024 = 20
028 = 25
034 =30
044 = 40
054 =50
the list goes on in increments of 10 untill it reaches 130 tons
134=130
Hope this helps
Best of Luck
Brand:
CARRIERManufacturer:
CARRIER CORP SYRACUSE
Model Number:
38ARZ008(5/6)0
Condenser Type:
air-cooled
Coil Model Number:
40RM-008--B5/6GC
System Configuration:
Split System Air Conditioner
Energy Efficiency:
10.6 EERCooling Capacity:
90,000 BTUs / hour
ARI Type Code:
RCU-A-CB
Electrical Service:
Triple-phaseElectrical Input:
8,490 watts per hour
Voltage:
230 and 208 and 460
There's a thumb rule in A/C air distribution. At 1 TR load, the air supply is about 400 CFM and the ideal diffuser size is 16" x 16" with an effective flow area of about 70%. Branch duct size for this outlet should be around 12" x 12".
