Will not start
A brand name and model with operating system would be nice so someone could be precise. ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
