Question about MTX Audio ThunderForm CXP20T Custom-Fit Enclosed Subwoofer - Chevrolet / GMC Extra Cab Pickup 1999-0... Car Speaker
1999 Chevrolet Suburban speakers
I have a 1999 Chevrolet Suburban with all speakers blown; I am looking for the size of the speakers for replacement options.
  • Anonymous Mar 22, 2009
    all of my spearkers are blown-out and i can't seem to find the right size to replace them.
  • Anonymous Apr 29, 2009
    Sergeant:
  • 300 Answers
According to Crutchfield.com, you have 6 3/4" speakers in the front and rear doors, 4"x10" in the rear pillars. The 6 3/4" locations should be able to fit 6 1/2" and 5 1/4" speakers using adapters. I would imagine the same could be said for using 6"x9" speakers in the 4"x10" pillar locations.
Posted on Mar 07, 2008
  • Tygh Duval
    Tygh Duval Mar 07, 2008
    To edit my comment, normally you can put smaller speakers in larger locations using adapters. In the case of your 4"x10" locations, you will probably not be able to install 6"x9" speakers, as the 6" height would be too tall. Sorry!
Actually, i have a 1999 chevy suburban and you have 6 1/2" in the front doors, 5 1/4" in the 2nd row doors and 4"x10" in the rear pillars, so you shouldnt need any adaptors. i am assuming you bought the suburban stock and not a special edition or anything.
Posted on Aug 12, 2008
SOURCE:
Why arn't my rear speakers and rear radio controls not working in my 2001 Suburban LT
1st thing simple ck all fuses did the radio go out
ar the same time as control and speakers
ck fuse first then take out and send to have looked
at maybe control unit hock up deferent spekers to rear
to see if there not blown then send out.
Jun 23, 2014 | 1999 GMC Suburban
My front speaker are blown and I am looking to replace them, where can I go to get new speakers.
I would try a salvage yard for the best price and good performance with original equipment fit and design.
Oct 29, 2010 | 1999 Oldsmobile Bravada
What is the spark plug gap for a 1999 Suburban 5.7L usink NGK plugs?
first off u should use ac delco platnum! wen u open the hood look for the tag that says catalyst it will say engine size ect it will tell you the proper gap!
Apr 02, 2010 | 1999 Chevrolet Suburban
1999 chevrolet suburban: door panel removal
hello here is the instructions for removing the door panel.
  • Remove the door handle bezel.
  • Remove the window handle,.
  • Remove the power accessory switch panel.
  • Remove the trim panel upper extension
  • Remove the trim panel screws.
  • Remove the courtesy light,
  • Remove door panel screws.
  • Remove the trim panel from the door, carefully sliding the trim panel up to release the retainers from the door.
  • Remove the speaker wire.
    Jan 23, 2010 | 1999 GMC Suburban
    2001 Chevy Suburban power outlets do not work even though cigarete lighter does. Is there a separate switch or circuit?
    yes most likely a fuse is blown for that circuit, look in fuse box for blown fuses, replace the ones blown ,hope to help ,robert b.
    Jul 11, 2009 | 2003 Chevrolet Suburban 1500
    Replacing factory radio
    Buy adapter harness from stereo shop simplifies problem and keeps factory harne in tack.
    Jun 19, 2009 | 1999 Chevrolet Suburban
    My remote key fob and the button on the dash, no longer open the back tailgate / liftgate on my 1999 Chevy Suburban. I'm guessing a fuse is blown, but I don't have an Owners Manual to look it up. Can...
    http://www.extendedgmwarranty.com/owners-manual/chevrolet/1999-Chevrolet-Suburban.pdf this link takes you to an online manual for your vehicle, after clicking on this link go to the "service and appearance care" and then "electrical systems" this shows you a layout of fuse box
    Please rate my help, thanks
    Apr 21, 2009 | 1999 Chevrolet Suburban
    1999 suburban no rear speakers after 1 blew
    This is an amp problem but you also need to confirm that there are no burnt wires and cut fuses.
    Rate this
    Apr 05, 2009 | 1999 Chevrolet Suburban
    1999 chevy suburban misfire
    could be one of several things
    1) run a compression check, if it low on that cyl then you have a blown head gasket or burnt valve
    2) could be the enjector
    Feb 26, 2009 | 1999 Chevrolet C2500
    Car Audio & Video Logo
    5,890 people viewed this question
    Top MTX Car Audio & Video Experts
    Professor_V
    Professor_V
    Mike Duncan
    Mike Duncan
    Philip Armitage
    Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
