Sony vaio vgn-fs775p laptop real time clock not running correct time even after reset the time it running slowly
Properly Configure Time Zone Make sure that you have properly
configured the time and selected the right time zone. Configuring the
time zone properly may fix clock that keeps resetting. To do so follow
these steps: Check CMOS Battery There is battery named CMOS
on the motherboard, if this battery becomes dead PC loses its date and
time settings. Problem in battery may result in this issue. Replacing
the battery with a new one is the best solution to fix the problem. Install Windows Update Some of the Windows updates
also contain a patch to fix clock keeps resetting. To download and
install latest Windows updates follow the steps below: Repair Windows Registry Mostly PC problems occur due
to corrupt Windows registry. To fix clock keeps resetting problem you
are required to fix registry error. You will need a good System
Utilities program that includes a Registry Cleaning feature. Registry
Cleaner deeply scans registry problems and fixes them instantly. To download System Utilities program including a Registry Cleaner click here. Scan System for Viruses Attack by viruses or spywares
on PC may also results in this problem. To fix this issue you have to
completely scan your system for malicious or infected applications and
clean all the files detected by antivirus program.
Hi
thank you for your query
If the time is not keeping up then it would seem that you will need to change your CMOS battery, this is a small battery found on the motherboard responsible for clocking etc
The battery is cheap to purchase, however I do highly recommned the laptop be booked into a reputable PC shop for replacement as you will need to take the whole laptop apart to get the motherboard
I hope this has been helpful
