Avaya Partner ACS 308EC (108463001) Expansion Module Logo
Anonymous Posted on Mar 09, 2010
How to access voice mail box away from office. No
How to access voice mail box away from office. No user guide available
A
Anonymous
Call in, when you hear the auto attendant or your amilbox, press "*7"
then it is just like sitting at your desk....
Testimonial: "Wow!! Thank you for such a speedy reply."
How can i access voicemails on NEC phone system model P4WW-12TXH-B-TEL(BK) please
You model number is the number of the phone that goes with the SL1100 Phone System. It have to be set up in the Management System first to be able to access from the phone. The designation (BK) signifies the phone is Black as opposed to (WT).
The NEC IP4WW-12TXH-B-Tel Phone 1100061 is a phone designed for the SL1100 system. The 1100061 is a 12 button phone featuring a full duplex speakerphone, headset jack, backlit display, and more!
NEC SL1100 Phone IP4WW-12TXH-B-TEL (BK) 1100061 ...
NEC SL1100 Telephone & Voice Mail User Guide
Interconnect Services https://www.interconnectservices.com > 2015/12 PDF TO ACCESS VOICEMAIL. ? From your phone press VM soft key. Follow prompts ... ? From outside the office, dial main number. When the voice mail system answers, ...
2 pages
Missing: bk) ‎' Show results with: bk)
NEC SL1100 Phone System Manual
Rhode Island Telephone https://www.ritelephone.com > uploads > 2019/04 PDF
1helpful
An Axxess Executive Digital Terminal: One of our
I am going to include a link to the administrator guide for you to download (its in pdf format). However here is what I found in the admin guide:
To change a password:
1. Access the voice mail administrator's mailbox and menu (see page 53).
2. Say "Mailbox Maintenance" or press to access the Mailbox/Group List Maintenance
option.
3. Say or enter the mailbox or extension ID to be accessed. You hear the Personal Options
Menu.
4. Say "Password" or press .
5. If you want a password, enter a new password using digits 0-9 (up to 12 digits) and
press when you are done.Voice mail plays back the password.
If you do not want to use a password, say "Skip" or press . Voice mail announces
that you have chosen not to have a password.
6. Say "Accept" or press to accept the password as entered, or say "Re-enter" or press
to erase and re-enter the password.
7. Hang up or press to return to the previous menu.
If this is not the right section then maybe one of these admin guides will help:
http://www.cmscomm.com/guides/axxesssAdministrator.pdf
http://pointz.com/pdfs/Axxess710AdminGuide.pdf
Hope it all goes well for you
How do I retrieve/listen to voicemail messages on my LG-P500 Android phone?
Phone require establishing voice mail boxes from were details are stored as an entity owner of device also to be mean from which communcatin sis attainable. Prior to establshing a mail box, the phone has be familiarised preferable from the user guide. usually the mails box requires for multimedia phones, a recorded voice of the owner also achievable by navigatimng the device system setting to locate an dactivarte personalmail settings. Ascertain details from the user guide that has illustrartions. Also, the is capable of provide navigational instructions of arriving at mail box area to establsih person details. Locate the phone menu settings buttons to explroe the features.
How to set up voicemail on a Samsung KPDCS-12B office phone
If an Engineer has previously set up a Mail Box on your Voice Mail, then you need to assign a VMMSG button to that extension. this will allow access to your Voice Mail. I have posted a Voice Mail training video for you to watch- if you need the key setting up, go to youtube and search 'abbeytel' look for the 'how to program a softkey', I hope this helps, written help is available at
http://www.abbeytelecom.com
Have user's guide cant find voice mail on phon...
its usually in one of your contacts if its a new Sim card if its not there then just Google your network provider for voice mail number for example search o2 voice mail number should be easy enough for you to find
I have a KX - T7730, how to set voice mail and to forward calls to outside number? The manual instruction is too confusing...
http://www.walterbridge.com/manuales/KXT7720-User-Guide.pdf
Get that guide, it is very straight forwards.
Setting voice mail, is only done, through the phone, not by, the phone. page 6 shows you how to log/In out. You need to do this first to be able to access the voice mail. Again, in same page, it shows you step by step via a drawing of buttons, each row of words explains another way to call forward, you just press the corresponding numbered button
HOW DO INDIVIDUALS RECORD PERSONAL GREETINGS?
It's done in the same manner. You dial the voice mail port from the extension and it should gate into the user's mailbox...if it exists.
By default the extension is 165 or 500, but it could be different.
If they never had working voice mail, they'll probably get the tutorial. If they did and it's someone else's box, you can delete it as an administrator (from 999 not 998) and add it again and it will clear the box and come up as a new user.
Once the box is established from remote or a different extension than their own, they can press #6 *ext at the main greeting to access their mailbox.
Carl
Delete old voice mail - program new voice mail
You can usually access the system voice mail setup from any extension.
Press Speaker
Dial ext 200.
When asked for security code, dial *,2,# (dial it twice if there is no code).
When main greeting begins, dial 632.
Using the soft keys under the display, press MORE, then MGR, then CHBX or, follow voice prompts if non-display phone.
Follow voice prompts. Remember, 1=Yes, 2=No.
2helpful
4helpful
3answers
"New Voice Mail" stuck on screen.
Hi, I have the same problem. I called the service provider, they left a voice message, which I accessed later and deleted from my voicemail box. This took care of it and I dont have that message on the screen now. I think you can just leave yourself a voice message and access it later and delete it. That should resolve it.
Top Avaya Computers & Internet Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
