KitchenAid K45SS Classic Stand Mixer Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My K45SS is leaking some kind of oil or grease from the part of the mixer above where the mixer part attaches. It otherwise seems to be functioning fine.
Tim Rickards
Level 2:
Sergeant:
  • Expert 296 Answers
  • Posted on Feb 02, 2014
Tim Rickards
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
63704
Points
847
The grease breaks down from age and the thin oil leaks past the seal, go to Ebay and buy new grease ($10) and replace it, Youtube videos show you how.
Anonymous
Level 3:
President:
  • Master 2,468 Answers
  • Posted on Mar 09, 2010
Anonymous
Master
Level 3:
President:
Answers
2468
Questions
0
Helped
707566
Points
7484
Its gear oil from the gear box that the motor turns to make the beaters turn,you need to replace the seals or keep adding food grade oil before you dry out the gearbox and ruin it
Oil leaking from the attachment head
The grease leaking out of the KitchenAid mixer can be a common problem. Here is the cause, and how to fix it, and prevent this issue from happening in the future.
The KitchenAid mixers use a Benalene 930-2 grease inside of them. It is a dark, thick grease that can break down and leak out of the mixer. The grease is a non-toxic vegetable based grease, basically it is a food grade grease. Over time, or if you do not use your mixer often the grease can break down, so it would appear that there is oil leaking from the mixer. It is most common for it to leak from the beater shaft (agitator shaft) and from the drip ring.
What you need to do is take the mixer apart, clean out all of the old grease, replace it with about 6 ounces of new food grade grease (http://www.mendingshed.com/kagrease.html). It is also recommended that your replace the o-ring on the center shaft (http://www.mendingshed.com/67500-55.html) and the gearbox gasket (http://www.mendingshed.com/mixergasket.html).
To prevent the grease from breaking down in the future if you do not use the mixer very often, it is recommended that you pull the mixer out and run it for about 2 minutes every 3-4 weeks, this should stop the grease from breaking down as quickly.
Please let me know if you have any questions.
This applies to mixer models, K45, K45SS, KSM75, KSM90, KSM103, KSM110, KSM150, KSM151, KSM152, K5, K5A, K5SS, KSM5, KSM50P, KP50 AND KPM5
Thank you,
Colleen
Customer Service
MendingShed.com
[email protected]
800-339-9297
K45SS leaks oil
Hiya,
I am sorry to hear you are having an issue with your machine! To solve this problem, you will need to remove the drip ring from your mixer and give it a good clean, this should stop the grease leaking.
I hope this helps you! :)
3helpful
Kitchenaid mixer leaking oil from head.how to fix it.
It's not oil, it's grease. Here is a very detailed article on how to add grease to the mixer. After you have added some new grease and tightened the screws it will stop leaking. The temporary fix is to simply remove the chrome ring as is done in the picture on the attached link, clean out the oil and stick it back on till it fills up again. It is called a drip ring for the reason that it catches the oil component of the grease which drips from the gasket when the screws loosen:
http://www.artisanbreadbaking.com/discussions/kitchen-aid.htm
9helpful
MY kitchenaid mixer has always oozed oil but suddenly today I can no longer attach the dough hook. The spring doesn't want to move enough for me to attach it. It was fine yesterday.
The oil that is "oozing" is actually grease. If it is laying on its side the grease will leak out but isn't really an issue. If it is leaking while the machine is right side up, it usually means you have a problem with the seal. When it comes to the spring not bending allowing the attachments to lock onto the shaft, that is a bizarre problem as the spring is just tension and isn't internally attached to anything inside the machine. If you want you can replace the planetary gear but that seems a bit drastic just for the spring. We usually recommend 1800Parts for parts and accessories because they carry EVERYTHING! So the seal they might have but I would bring the machine to someone to look at the planetary gear to make sure everything is in working order. If you are in New York you can bring it to us.
Leaking oil above beater
the gearcase grease and housing gasket needs replacement. this will require alot of disassembly and the use of kitchen aid specific grease.
1helpful
Oil leaked when inadvertently stored on its side. what kind of oil do i need and where do i get it? thanks brian
gear grease is kitchen aid specific; sold by the can though a KA part supplier. while you're at it, replace the gear housing gasket as well.
We have a kitchenAid mixer [ K45SS-WH-O ] when we
1helpful
Leaking grease around the area where the attachments are mounted
Carefully pry the chrome ring from the gearhead of the mixer. Item 28 on this page :
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
You will find 5 screws under the chrome ring. Tighten them and the oil (grease) will stop leaking from the gasket which seals the gearcase halves.
My classic k45ss leaks oil which drips from the verticle shaft, and my wife says it is making a "funny noise". Maybe it is low on oil, but I turned it on its side to find the model number, and it leaked...
Firstly I would take the head apart to find out what has failed. The oil you see should be a thick grease. Normally it is thick enough not to leak in this way. Has it been repaired and the wrong grease used? If it is making a funny noise it could be that one of the gears has failed. Most parts are easily available. Have a look at the parts list at:
3answers
K45SS leaks lubricant
I went to Kitchen Aid'sKitchen Aid's web site and had an on line chat with a tect support person name Jessica. She told me that if the mixer is not used a small of oil will leak out. to fix the problem you must run the mixer for a few minutes every month or so. This seems to work.
Rick
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
