Linksys Wireless-G Broadband Router Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a linsky wireless G 2.4 Ghz 54Mbps (model WRT 54G) I have the cd, but I do not have the password. I am not sure if this is the reason, I can't set up my network. How do I get another password
Anonymous
Level 2:
  • Expert 93 Answers
  • Posted on Mar 09, 2010
Anonymous
Expert
Level 2:
Answers
93
Questions
0
Helped
27212
Points
280
Linksys WL router always has default password "admin" you will have to reset router to factory defaults by plugging Pin in to Tiny Hole on Router back side for 5 seconds. and then login by default ID "admin" and password "admin" to configure router again. [Remove Inverted Commms from User name password while entering
Wireless 2.4ghz router for wifi
Wrt54g can be used as either a wireless router or access point. I am not familiar with your broadband service, but if it has a data port just connect it to Internet port.
I need to reset the password on my linksys Wireless GBroadband router WRT 54G without ruining my wireless set up in my house!
Use an Ethernet cable to connect your computer directly to the router.
Access the web-server "inside" the router.
Login to the router, with the current ID/password.
View the wireless settings:
* SSID
* encryption-level ('WPA' or better, please)
* network password
and change it, if you need to.
I want to set up my Wireless-G 2.4 GHZ 54Mbps
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
2answers
Hi Ive connected my linksys wrt 54g working fine on main puter but can't connect on my laptop .It's showing strong reception but then says cannot connect,Thanks,Guy
Check in the router settings, in your internet browser from your deskyop, type 192.168.1.1 and enter the router config screen by using a blank username, and admin for a password. Look through the settings and make sure it is set to wireless signal on. Also, look to make sure your laptop isn't made specifically for Wireless N technology. Some wireless adapters aren't backwards compatable.
6helpful
2answers
Need the driver for Linksys WRT300N V1 ... can't find the CD
The LINKSYS WRT300N is a standalone device, there are no software/driver needed on your PC for the router to work. However, there is an easy Setup Wizard that is in the CD that normally comes with the unit.
Unfortunately, Linksys did not make the specific Setup Wizard (Version 1.3) for the WRT300N available online. However, if you care to try the Setup Wizard for a WRT54GC, it may downloaded from the LINKSYS ftp site here. I used to have a WRT54G and I did make use of the Setup Wizard for that model. I upgraded to WRT300N. The setup wizard for the old WRT54G worked likewise on the new WRT300N.
Alternately, the WRT300N can still be configured without the CD or the Setup Wizard by logging into the Configuration Page (192.168.1.1). Remember to use LAN interface when setting the router (as shown in the connection diagram) and set your PC to an IP Address of 192.168.1.2, Subnet Mask of 255.255.255.0; Follow on screen instructions and enter settings/configurations manually.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information. Additionally, if you still prefer to have a copy of the original WRT300N Setup Wizard, pls include your email address that I may send it to you as an attachment.
Good luck and kind regards.
Cannot access router webpage
Make sure your firewall and anti-virus are switched of then try and connect to the webpage
Top Linksys Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
