Rangemaster Kitchen Hood Logo
Posted on Mar 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Problem with cooker hood
Hi, We purchased a Classic 90 cooker hood a couple of months ago, wall mounted. I don't think it seems to be taking the cooking smells out the kitchen as efficiently as it should, could it be faulty. Thank you. Julia
A Miller
Level 3:
  • Master 8,404 Answers
  • Posted on Mar 09, 2010
A Miller
Master
Level 3:
Answers
8404
Questions
Helped
2053147
Points
24677
Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
1helpful
I seek instructions for replacing filters (not the metal ones) in an Elica cooker hood.
WHY THE HOOD
THE HOOD IS ESSENTIAL TO BREATHE CLEAN AIR IN THE KITCHEN.
ITS MAIN FUNCTION IS TO IMPROVE THE QUALITY OF AIR, BY ELIMINATING BURNING FUMES, BAD COOKING ODOURS AND VAPOURS THAT ARE HARMFUL TO BOTH PEOPLE, FURNITURE AND WALLS. THE HOOD IS A VALUABLE ALLY FOR YOUR WELLBEING.
THIS IS WHY, WHEN CHOOSING ONE, YOU NEED TO MAKE SURE THAT IT PROVIDES:
  • SUCTION PERFORMANCE SUITABLE FOR YOUR NEEDS AND ENVIRONMENT, IN ORDER TO OBTAIN PROPER AIR FLOW AND LOWER ELECTRICITY CONSUMPTION
  • EFFECTIVE LIGHT SOURCE TO FACILITATE FOOD PREPARATION
  • DESIGN THAT SUITS YOUR TASTE AND NEEDS
  • GOOD USABILITY AND LOW NOISE LEVEL
HOW TO CHOOSE IT
CHOOSE A HOOD THAT FACILITATES YOUR WORK IN THE KITCHEN, AFFORDS FREEDOM OF MOVEMENT AND SIMPLIFIES FOOD PREPARATION.
THE HOOD SHOULD ALSO HAVE THE RIGHT SUCTION POWER. CONSIDER THE SIZE OF YOUR KITCHEN AND YOUR COOKING HABITS: THIS IS THE ONLY WAY TO OBTAIN THE RIGHT AIR FLOW AND LOWER ELECTRICITY CONSUMPTION.
A SIMPLE CALCULATION ALLOWS UNDERSTANDING THE MOST SUITABLE CAPACITY FOR EVERY KITCHEN. JUT MULTIPLY THE VOLUME OF THE ROOM BY 10 TO OBTAIN THE IDEAL CAPACITY.
CHOOSE YOUR HOOD CAREFULLY AND BRING NEW AIR INTO YOUR KITCHEN. THERE IS A WIDE RANGE OF INSTALLATION OPTIONS,
FIND THE MODEL THAT BEST SUITS YOUR ROOM, LIFESTYLE AND WAY OF BEING
WALL-MOUNTED THE KITCHEN UNIT IS LOCATED AGAINST THE WALL WITH THE COOKTOP ADJACENT TO THE WALL. HOOD TO BE MOUNTED ON THE WALL.
ISLAND THE KITCHEN UNIT IS LOCATED AT THE CENTER OF THE ROOM WITH THE COOKTOP AWAY FROM THE WALL. HOOD TO BE MOUNTED ON THE CEILING.
CORNER THE KITCHEN UNIT EXTENDS ALONG TWO WALLS OF THE ROOM AND THE COOKTOP IS LOCATED IN THE CORNER. HOOD TO BE INSTALLED BETWEEN THE ADJACENT WALLS.
BUILT-IN THE COOKTOP IS LOCATED UNDER A WALL UNIT. HOOD TO BE INSTALLED INSIDE THE WALL UNIT.
HOW TO INSTALL IT
THE CORRECT OPERATION OF YOUR HOOD IS ONLY ENSURED IF IT IS INSTALLED BY SPECIALIZED TECHNICIANS. ASSEMBLY AND MAINTENANCE VARY ACCORDING TO THE TWO TYPES OF HOOD: DUCT-OUT AND RECIRCULATING.
MANY ELICA MODELS CAN OPERATE IN BOTH VERSIONS. WHEN INSTALLING YOUR HOOD, BEAR IN MIND THESE SIMPLE BASIC RULES:
  • FOLLOW ALL THE STEPS SHOWN IN THE INSTRUCTION MANUAL OF THE PRODUCT;
  • CONNECT THE DUCT-OUT HOOD TO THE OUTSIDE WITH A DEDICATED PIPE: MINIMIZED LENGTH AND ABSENCE OF BENDS ENSURE BETTER PERFORMANCE.
  • COMPLY WITH THE MINIMUM DISTANCE FROM THE COOKTOP SPECIFIED IN THE MANUAL, IN ORDER TO AVOID DAMAGING WORKING PARTS AND ENSURING PEOPLE'S SAFETY;
  • MAKE SURE THAT THE OUTLET CHE IS CLOSE TO THE PRODUCT FOR CONNECTION.
  • IN THE EVENT OF DIFFICULTIES, SEEK ASSISTANCE FROM A RELIABLE SPECIALIZED TECHNICIAN;
ASSEMBLY
VARIES ACCORDING TO THE TYPE OF HOOD, DUCT-OUT OR RECIRCULATING
DUCT-OUT HOOD THE DUCT-OUT HOOD EXHAUSTS AIR TO THE OUTISDE. THIS IS THE MOST USED TYPE, BECAUSE IT ENSURES HIGH PERFORMANCE, HIGH CAPACITY AND LOW NOISE LEVEL.
RECIRCULATING HOOD THE RECIRCULATING HOOD REMOVES BAD ODOURS BY MEANS OF A DEDICATED CHARCOAL FILTER AND REINTRODUCES AIR INTO THE KITCHEN. THIS TYPE IS SUITABLE FOR ROOMS WITH NO EXTRACTOR DUCT, AFFORDS AIR SAVING AND AVOIDS THERMAL LOSSES TO THE OUTSIDE.
TAKING CARE OF IT
TO ENSURE THE LONG LIFE AND CORRECT OPERATION OF YOUR HOOD IN BOTH DUCT-OUT AND RECIRCULATING VERSIONS, THE FIRST STEP IS TO KEEP THE FILTERING SYSTEM IN GOOD CONDITION.
THERE ARE TWO TYPES OF FILTERS:
  • THE GREASE FILTER PROTECTS YOUR HOOD BY TRAPPING PARTICLES OF GREASE. THE ALUMINUM OR STAINLESS STEEL GREASE FILTER REQUIRES PERIODIC CLEANING BY HAND WITH NEUTRAL DETERGENT OR IN THE DISHWASHER AT LOW TEMPERATURE (*). THE PAPER GREASE FILTER MUST BE REPLACED EVERY MONTH DEPENDING ON USE.
  • THE ACTIVE CHARCOAL FILTER INSTALLED ON RECIRCULATING HOODS, TRAPS ODOUR PARTICLES OF AIR. REMEMBER TO REPLACE IT EVERY 3-4 MONTHS. LONG LIFE FILTERS HAVE A LONGER LIFE: THEY MUST BE REPLACED EVERY TWO YEARS.
SIMPLE PRECAUTIONS WILL HELP YOU KEEP YOUR HOOD IN PERFECT CONDITION.
(*) always follow the instructions for washing the filter on the manual of the product
Bosch DKE 997E wall cooker hood doesn't work properly
EN Control buttons separating from control mounting bracket. Affected Countries CA, US Affected Appliances HPCN36NS/01, HPCB36NS/01, HPCN48NS/01, HPCB48NS/01 Fault description / Customers complaint / Diagnostic Codes Diagnostic Codes (DC) The following table contains the diagnostic codes, which most commonly occur in connection with the mentioned fault description. Depending on the actual information from the customer, other diagnostic codes are possible. DC Fault description of the customer 160100X45000 Mechanical damage / Holder Root cause On some Thermador Professional hoods with FD 9407 to 9611, the control buttons may separate from the control mounting bracket due to insufficient adhesive between the control mounting bracket and the inside of the hood canopy. Solution Beginning with FD 9612, wider tape was implemented in production. For units built prior to that time, service kit 12022532 is available. The new repair kit includes the control-mounting bracket with wider tape affixed to it, and four screws. The tape will provide more surface coverage to improve the support of the mounting bracket.
1helpful
I purchased the elite rice cooker short of four months ago. I've used it 10-12 times since the time of purchase. Up until now i was in love with it, i told everyone how great it was but tonight im not so...
open the bottom side of your unit.. then check the resistance of thermal fuse, it's look like resistor which is connected to line wire, usually covered by insulator..
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Don't know what electricity supply is required
Emmet in luton: what fuse does a rangemaster 90 duel fuel need?
2answers
National brand rice cooker
Hi. Checked on Australian Panasonic spares website for part no ASR111-494F and apparently it's no longer available. Panasonic spares would all come from the same source, so it's a good chance it's unavailable worldwide. Sorry.
3040 VG
I need a knob for a slow cooker 3040 Rival [email protected]
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
